Tire Damage Concern
Old Jul 19, 2010 | 01:26 AM
sukjeffrey's Avatar
Default Tire Damage Concern
http://www.flickr.com/photos/5100101...n/photostream/
Here are the pictures. I'm wondering if a tire change is necessary. I got this about 2-3 hours ago while I was taking a right at an intersection. I hit a red curb. There aren't any dents on the rim, just a lot of scratches. What are your thoughts?
Thanks in advance.
Old Jul 19, 2010 | 01:50 AM
Young-Gun's Avatar
It's kinda hard to tell when the pictures don't work.
Old Jul 19, 2010 | 02:03 AM
sukjeffrey's Avatar
http://www.flickr.com/photos/51001013@N07/4806351897/
Sorry, I don't know why the link changed.
Old Jul 19, 2010 | 02:22 AM
sciontc_mich's Avatar
Thanks in advance.
yeah i'd replace the tire. Tire sidewalls have a matrix of nylon/polyester/rayon etc.. well depends on what the tire is made of but you get the idea. And if you chunk off a piece of rubber you get closer to that material inside the tire. It basically is a weakened tire now. Could blow out because of the weakened sidewall. So yeah if that was my tire i'd get a new one.
Old Jul 19, 2010 | 02:23 AM
DJ08tC's Avatar
yes i would be worried about that since that is all the way to the steal.
Old Jul 19, 2010 | 03:16 AM
jnaval's Avatar
Any sidewall damage usually leads to tire replacement, your case is more severe.
Old Jul 19, 2010 | 07:49 PM
RoboCop's Avatar
Ouch man. I had some sidewall shred off once but it was only the top rubber layer and my uncles shop said just to cut it off to prevent it from wanting to peel. Yours on the other hand is pretty bad.
Old Jul 19, 2010 | 09:12 PM
SoulXquisite's Avatar
-yup get it replaced
Old Jul 19, 2010 | 11:33 PM
Un4Scene's Avatar
From: Living in the Omaha, NE area, traveling all over the continent
That's bad, and should be replaced, but it's not really an emergency repair situation. You can probably drive on that for a while as long as you take it easy through the curves and corners, and keep your speed down. However, if you do drive on it make sure you check it every time for any bulging anywhere on the sidewall. If it starts bulging at all, or if you feel any vibration start while you're driving then make sure you stop immediately and get it replaced, as that probably means the tire is about to blow. Don't get me wrong, driving on it at all is a risk, but unless it gets worse it's a fairly low chance.
Old Jul 19, 2010 | 11:38 PM
Domo's Avatar
I wouldn't worry about it. I assume you hit a curb. This happened to my girl and we continued to drive on her tires for 1500 or less more miles. We eventually swapped the tires because she needed a change (30000+ miles on Yoko S3) but the tires ran fine.
Oh but do change the tires when you get the money but if you don't have the fundings at this moment, just take it easy.
fur_pig
Mar 20, 2020 04:28 PM
Fisqual
Sep 22, 2015 05:51 AM
viciouzgamer
Feb 18, 2015 03:26 PM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
fur_pig
Dec 5, 2014 12:48 PM
