trouble closing sunroof
Old Jul 20, 2010 | 06:25 PM
sciontC's Avatar
DeepSouth Scions
Default trouble closing sunroof
Yesterday when I got home and pulled in my garage I went to close my sunroof like any other day. However this has been happening on and off last 2 days. When I press the close button it will look like its going to close then automatically stop and reverse and open itself back up to the position I started closing it at. Yesterday it would not stop doing this until I thought of an idea to apply slight pressure to it while pressing close which enabled me to close it yesterday.
Have any of your experienced something similar to this? What do you think I should look at/ try, or is this something I should head to the dealer for?
Old Jul 20, 2010 | 06:43 PM
RoboCop's Avatar
Check the tracks. Maybe put some lube in the tracks. If it meets resistance, it is programmed to stop.
Old Jul 20, 2010 | 06:49 PM
Un4Scene's Avatar
From: Living in the Omaha, NE area, traveling all over the continent
I occasionally have the same problem with mine. It just started a couple weeks ago, and it's been intermittent, so I haven't bothered to do anything about it yet. I've found that letting off the close button just before the point where it stops, and then tapping the button till it's closed all the way works.
I'm guessing that one of two different things is causing it. Either it has some sensor that's gotten dirty that detects when something is blocking it's path (like a garage door), or it's encountering too much resistance when trying to close and programmed to reverse itself (like a power window). I think the latter is more likely, but I haven't looked to see what could be causing the resistance yet.
Anyone else got any ideas or solutions?
Old Jul 20, 2010 | 06:54 PM
tin's Avatar
tin
I have this prob everytime i open it all the way. So to close the sunroof i hold down the small piece of glass that opens fwrd and proceed on closing it. It started doing that years ago.
Old Jul 20, 2010 | 07:16 PM
theregulator's Avatar
Scionetics
exactly what i do loll...or if i drive fast enough n the wind applys enough pressure for me so itll close fine =p... i thot it was because i replaced my glass deflector with black lexan... i figured it was lighter so thats why it needed help closing... guess not lolzzz
Old Jul 20, 2010 | 07:20 PM
tin's Avatar
tin
Hahahah yeah on the freeway i can close it normaly too. I never botherd fixing mine, i really dont drive with the sunroof open all the way anyways.
Old Jul 20, 2010 | 07:51 PM
PDXSciontC's Avatar
Shortly after buying mine (used) I experienced this problem myself. The springs that allow the front deflector to pop up are very strong. If the hinges on it are not properly lubricated, it causes too much resistance for the sunroof to pull down, and caused it to reverse. I lubricated the hinges on the deflector, and no problems at all since. Hope this helps!
Old Jul 20, 2010 | 08:13 PM
fmtc4ever's Avatar
it happened to mine i took it to the dealer and they cleaned the tracks and lubed them
Old Jul 20, 2010 | 09:03 PM
tin's Avatar
tin
Dood good info. Thank you for this.
Old Jul 20, 2010 | 09:39 PM
mangoagogo's Avatar
definitely check the tracks looks like something is stuck/dirt.... hopefully you get it solved soon
Old Jul 22, 2010 | 10:29 PM
sciontC's Avatar
DeepSouth Scions
Well I put some stuff on the deflector hinges and it hasnt happened since...so im going to say that was the issue, thanks
yupinmytC
22
Jul 27, 2024 07:08 PM
BlingSlade
Oct 19, 2016 12:39 AM
vi3tb0i09
Sep 23, 2015 08:32 PM
DannyBoy65
Sep 21, 2015 06:23 PM
atlantaemail
Sep 20, 2015 02:03 AM
