Help + Research on Led Lights for xa
Well i went to autozone and yes they still had for my honda prelude the LED bulbs for my tail lights
.......anyway
I went there to research about xa Led bulbs and i took one just to try and yes it does work but the bulb is kinda big so it cant fit into the housing ....so u have to do like custom "cut the rounding" ................
so if somebody knows how to get away with cutting etc and still have led tail lighs that would be awsome
.......anyway I went there to research about xa Led bulbs and i took one just to try and yes it does work but the bulb is kinda big so it cant fit into the housing ....so u have to do like custom "cut the rounding" ................
You can get the correct light codes for the entire car at:
http://www.sylvania.com/ConsumerProd...placementguide
Select the appropriate car. . .
Then just order led's that approximate the light number your replacing.
Originally Posted by zdawg913
what bulb is it? pricing? that sounds really cool, i want more info too... sounds like a good project
for me it worked while the bulb was outside the taillight housing .........so the only thing we need is the same Led bulb but little bit smaller........so it can go in............
yesterday on ebay i found this !! but duno if its working
seeeeeeeeee they do have for tc and xb WHAT ABOUT XA ?????????
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
This is what i found on internet
http://www.superbrightleds.com/specs/7443.htm
got to scroll down
http://www.superbrightleds.com/1157.htm
Here is the description i will buy it and give a try this are leggal !
7443-15 LED bulb
12VDC Dual Contact 15mm wedge base replacement bulb
15-LED Design has 9 LEDs aiming out the end and 6 radially mounted LEDs aiming 90 degrees from the base
Select White, Red or Amber LEDs
$ 6.99
got to scroll down
7443-15 LED bulb
$ 6.99
i have led taillight bulbs in my car. The Scions are wired differently than most cars, so the polarity will be backwards on one filament. I had to do some custom wiring to make them work. Its not a simple mod.
ktb53
21
Jan 5, 2005 01:59 AM
crystaljukebox_com
39
May 14, 2004 04:55 AM
sithscripter
9
Sep 26, 2003 05:27 AM
