LED Underglow Mounting Question
Old Aug 9, 2010 | 02:22 AM
Basebllstar's Avatar
Default LED Underglow Mounting Question
Okay, I've seen the install guide for installing an underbody kit on a scion tc on oznium. I bought a kit secondhand. If i buy the mounting kits that are sold on oznium is it safe to use the screws included to screw into the bottom of my car? I don't know if the floor in these cars are a simple sheet of metal or if there's some sort of buffer. I just dont want to go to install this thing and end up with screw points coming through the carpet.
Old Aug 10, 2010 | 04:04 AM
70 views and no help?
Old Aug 10, 2010 | 06:33 AM
fewjative's Avatar
Is the neon for show?
Old Aug 10, 2010 | 02:36 PM
Yes, I plan on driving with it off, if that's what you're asking.
Old Aug 10, 2010 | 02:42 PM
cobaltbravo's Avatar
You can drive screws into the underside of the car, just make sure they're no longer than a half inch. I recommend coating the threads and heads with rtv or sillicone to help prevent rusting of the sheetmetal. Under most of your carpet is carpet padding, the screws shouldn't penetrate thru that if you're careful. If you're leary of screws sticking thru the carpet, use rivets.
Sent from my Droid
Old Aug 11, 2010 | 07:02 PM
Thank you, just the answer i wanted.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
tc_Jake
Dec 31, 2014 01:45 AM
fearturtle44
15
Feb 13, 2004 01:15 AM
