new to the scion life
Old Aug 12, 2010 | 05:03 AM
lilbluetc's Avatar
Default new to the scion life
so i am new to the scion thing going on and i have a few things done to my car want ideas on where to go next
cold air intake done
light weight crank pulley done
dc sports 421 headers done
greddy ti-c catback exhaust done
where do i go next
Old Aug 12, 2010 | 05:05 AM
tCs_are_life717's Avatar
drop the car, get some new rims and tail lights?
1GreeKtC's Avatar
I suppose a drop is in order.
Old Aug 12, 2010 | 05:07 AM
lilbluetc's Avatar
nope wanna go engine first
Old Aug 12, 2010 | 05:11 AM
-air diversion panel
-upgrade your hoses
-upgrade your throttle body
-midpipe or s-pipe
its up to you.
Old Aug 12, 2010 | 05:18 AM
1GreeKtC's Avatar
Go turbo.
/thread
Old Aug 12, 2010 | 05:20 AM
i was gunna say the same thing, but i think if he wanted to do that he wouldnt have spent the time picking up a header and intake
Old Aug 12, 2010 | 05:21 AM
lilbluetc's Avatar
wanna go n/a i drive across country so i dont need mad power just want a little bit more fun
Old Aug 12, 2010 | 01:04 PM
ack154's Avatar
You'd have a lot more fun if you throw on a rear sway bar and a decent set of springs. Trust me on that.
For what you spend on the engine and the little tiny bit of power you gain from it, you'd be WAY better off putting that money into suspension.
Old Aug 12, 2010 | 01:21 PM
cavalierkid888's Avatar
^^^x2
Old Aug 12, 2010 | 06:55 PM
Kanchi's Avatar
gotta agree with ack. Get a rear sway, some H&R springs and hawk brake pads and tear it up!
Old Aug 13, 2010 | 09:39 AM
lilbluetc's Avatar
wow this has been no help at all except for tcs are life 717 would like new ideas in stead of just lowering it and adding brake pads and sway bar what about cams or some other engine upgrade
Old Aug 13, 2010 | 06:07 PM
Kanchi's Avatar
^well it depends on what your end goal is. If you want to go turbo then there is no sense spending money on certain things vs na/supercharged. If you want motor upgrades this is what I would do in order:
Overall:
-Silicone hoses
-radiator & diversion pannel
-flui-dampener crank pulley (only balanced one on the market)
-Ingalls "Stiffy" ETD/Energy supension motor mounts (lets you put the power to the ground better)
if you go turbo:
-all of the above then
-Quality full turbo kit (Decendant/Dezod/Ptuning/Turbonetics)
-Immediately get it tuned before driving
-LSD for tranny w/ performance clutch
-Decendant intake manifold (optional)
-Get re-tuned
-Methanol (optional)
-Get re-tuned
-FI cams
-Get re-tuned
on and on...
If you go supercharged:
-All of the top listed then:
-wrap headers.
-Upgrade and replace bearings in supercharger
-WR intake
-9lb pulley
-Call it good & pray the bearings don't go out
If you stay N/A:
-All the top listed stuff @ the top then:
-Throttle body spacer
-Remaining pulley set
-stage 1 cams
-Rebuild bottom end (balanced crank, lightened rods, yada yada)
-LSD, flywheel, & clutch
Hope that better answer your questions, purely my opinion but thats what I would do.
Sincerly
-Kanchi-
Old Aug 13, 2010 | 09:56 PM
happy birthday lilbluetc
Old Aug 14, 2010 | 02:28 AM
Vlad1024's Avatar
X2
it is widely known that tb spacers are snake oil but i don't want to argue.
Contrary to what people seem to think toyota engineers it's engines to produce the most power they can so engine mods give you minimal power gains. After i/h/e and pulley(which may or may not affect reliability, search) there isn't anything you can do(except f/i). These car's are not fast, they are cheap and reliable(remember "reliable, fast, cheap. pick 2"). That said there are plenty of mods that make the car more fun to drive. To improve shifting(manual only) you could get a flywheel(engine spins more "freely" when shifting), better motor mounts, or a ingalls "stiffy" engine torque damper(both reduce wheel hop and keep the engine still).
While slow our cars do have good handling and a few mods will make them out handle a lot of cars(as proven by autox). Good springs(NOT SLAMMED) with matched dampers(struts)(like trd struts and trd spring or coilovers). paired with a stiffer rear sway(progress) will maximize handling. Also tires. Stock tires suck so you will really feel better tires.
2CTC
Sep 12, 2015 11:33 AM
JonathonK
Jan 11, 2015 01:14 PM
AdPock
Jan 3, 2015 12:12 AM
JonathonK
Dec 30, 2014 12:18 AM
JonathonK
Dec 6, 2014 12:13 AM
