turbo question
Old Aug 24, 2010 | 05:15 AM
1badtc05's Avatar
Default turbo question
ive been researching different turbo sizes to run on my stock motor. im wanting to get around 300 whp but not sure whats the best size turbo to go with. i also went to some local shops to see what they would tell me.
if you guys could help me out and tell me what would be the best turbo for 300 whp.
Old Aug 24, 2010 | 05:41 AM
gingles's Avatar
if you have the money get a 60mm turbo....that way you wont have to upgrade if you decide to go bigger....new you can get a precision one for around 700 bucks....keep it a .63 ar exhaust housing so you can get a quick spool.....id say around 12-14 psi youll be close if not at 300hp depending on tune.
Old Aug 24, 2010 | 01:25 PM
1badtc05's Avatar
what do yout think about a precision 6262
one of the shops i went to told me they would build me a kit with that size. but i didnt know if that would be to big.
Old Aug 24, 2010 | 05:46 PM
m6ar2cel6oTC's Avatar
That's a pretty nice size turbo if you can get it for cheap great if not go smaller. How much they charging to make you a kit? And have they ever worked on a tc before?
Old Aug 24, 2010 | 06:04 PM
1badtc05's Avatar
i went to a couple local shops but the one that wants to use the precision 6262 wants 3800 installed. they said they build a couple and i actually saw one they built. they built the motor and put together a kit for it. but they used a gt30 on that car.
Old Aug 24, 2010 | 06:20 PM
paul_dezod's Avatar
Scionetics
KAD
6262 is a decently large turbo and unless you want a more top end oriented power band, want to make 450whp or more, I would consider something smaller.
What are your power goals for the car? What is the use of the car?
Old Aug 24, 2010 | 07:29 PM
Got pictures of the kit? And what else does the kit come with? If it's 3800 complete with injectors fuel management and that turbo with install that's a hell of a deal. I hope they use quality parts.
Old Aug 24, 2010 | 07:45 PM
1badtc05's Avatar
so what turbo do you recomend?
yeah its a complete deal with all good quality parts.
treadstone manifold
precision 6262
aem fic
tial wastgate
hks ssqv
walbro fuel pump
rc injectors
gauges
etc.
basically everything you need to turn the key
Old Aug 24, 2010 | 07:49 PM
1badtc05's Avatar
and my goals for the car are 300 whp and maybe later on build the motor.
but its my dd
Old Aug 24, 2010 | 10:19 PM
Damn if it comes with what your saying jump on that deal asap. GL!!! Hey get the 6262 and I'll trade you for my 60-1. It's a lil smaller then that 6262. Hehehehehehe
Old Aug 24, 2010 | 11:17 PM
weezyfbayba's Avatar
ive got a garret 60-1 for 550 shipped and the 60-1 is alot smaller lol
Old Aug 25, 2010 | 02:27 PM
paul_dezod's Avatar
Scionetics
KAD
If 300whp is your goal, run a 50, 54 or 57 trim. All work very nicely on this engine and provide good power bands from say 3400-6500 RPMS. Here is recent 50 trim tuned...
Not impressive peak numbers, but great power from 3200 to redline of 6600
Old Aug 25, 2010 | 03:10 PM
skinnayyy's Avatar
Team Scionara
i run a 57 trim, and on a super conservative tune, at 10 psi i made 286.
edit: i also reach max boost at ~3300 rpm
Old Aug 25, 2010 | 03:38 PM
BlckdOutTC's Avatar
57 trim tuned to 5psi 220whp full boost same as above
Old Aug 25, 2010 | 04:51 PM
egobuster1's Avatar
im in the same boat as the OP as on my tC i dont wanna build the motor yet because i cant afford it until after this first year of school
my goal is to get right around 300whp maybe little less depending because i dont wanna blow the thing up.
now i know that for this goal it would be most logical to get a smaller turbo because i would like to be full spooled at about 3500 to 4k RPMs as that leaves enough room there for daily driving with out hitting much boost
as for my noob questiosn i dont know really much about turbos and i dont know how the sizing is done to determine if its small or not
hope this makes sense and i think itll also help the OP
also if there is someplace i can go and read and learn about all this stuff please link me
Old Aug 25, 2010 | 07:12 PM
skinnayyy's Avatar
Team Scionara
look at the stickies in the FI section. tons and tons and then a little more info.
Old Aug 25, 2010 | 09:28 PM
BlckdOutTC's Avatar
a nice t3t4 setup will support you well enough. most kits on the market come with a turbo that size or close to it. that being said, a t3t4 with a good tune will easily get you 300 to the wheels when tuned to say 10psi give or take 1 or 2 psi (tune,climate,elevation,etc.)
Old Aug 25, 2010 | 11:01 PM
1badtc05's Avatar
i ended up going with a precision 5857.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
