Which Hood Pin Lock is better?
Old Oct 20, 2010 | 04:23 AM
jordankinship's Avatar
Default Which Hood Pin Lock is better?
I'm getting a Kaminari CF Hood, so I might need a hood pin lock as well.
Can you guys give me some advice on it?
___
Old Oct 20, 2010 | 07:05 AM
Mouse's Avatar
Well I could be wrong, if I am, by all means if someone has actual hands-on experience chime in for the OP... but I've seen several different cf hoods installed on tC's and I don't remember seeing any of them utilizing hood pin locks.
So that leads me to believe that at least some of the cf hoods for our tCs are designed to use the OEM hardware. With that said, unless you're building a car that is ONLY meant for use in a track/race setting.... I'd stay away from using hood pins if you have the option to use the OEM latch hardware, simply because even if you install the pins, the act of drilling a hole(s) in any solid panel can possibly compromise the integrity of it, especially over time.
That's just my 2 cents on the subject... hope that helps in your decision process.
Old Oct 20, 2010 | 02:41 PM
MeatRocket's Avatar
this^^^
kaminari hood is well built, you do not need hood pins on it. i have had mine for almost 3yrs and have been at speed close to 100mph at the track with no issues.
Old Oct 20, 2010 | 02:48 PM
Originally Posted by MeatRocket
this^^^
Sure, this definitely help
Can you show me what is the oem latch like?
Old Oct 20, 2010 | 05:49 PM
Spicy_McHaggiz's Avatar
If you do decide to go for a hood lock, go for the first style that you posted. Much more secure and discreet. However all aftermarket CF hoods for the tC utilize the factory hood latch, so you shouldn't have a problem.
Old Oct 20, 2010 | 06:52 PM
base on what you guys say, sound like I dont need one
Old Oct 20, 2010 | 06:53 PM
cavalierkid888's Avatar
I've got the first ones you posted (aerocatch) with my seibon. Though I also use the oem latch as well. I'd rather be safe than sorry, but that's just me, i'm kinda paranoid. haha
Old Oct 20, 2010 | 06:58 PM
Can u show me pic of how it look like on your hood?
itscurtsk
Scion xA Aero & Exterior
Dec 27, 2011 06:50 PM
skinnayyy
Scion tC 1G Aero & Exterior
Feb 19, 2010 11:22 AM
DEEMO
Jul 26, 2007 02:47 AM
depogrig
22
Oct 2, 2005 11:13 PM
05polarxb
Jan 26, 2005 04:53 PM
