Started on the paint for my tC
Old Nov 17, 2010 | 09:52 PM
minter66's Avatar
Default Started on the paint for my tC
Over the past couple of months I have been scrounging and searching and piecing together an OEM GFX kit. Well this past weekend it was a bit cold, but I went ahead and sprayed the pieces.
Sanded and wiped down with reducer
Paint and supplies. 1:1 ratio with this 2 stage paint I bought
Looks terrible in the cup...
Base coat on successfully! Gorgeously flat!
Unfortunately as this is my first time spraying, I apparently didn't put enough hardener in my clearcoat or I just sprayed way too thick and slow and I had runs galore!! Now I have to block sand it back to smooth and spray base/clear again...grrr
Anyone have tips on spraying clearcoat? It is SO much different than basecoat...
Old Nov 17, 2010 | 09:57 PM
Joyride's Avatar
Clearcoat is the devil, I hate it so much. When i first started spraying i would get cracks, and runs all the time. The worst part was sanding them down so tedious, and i always felt unsatisfied with my results.
I say do two mist coats, then one medium, and then a little bit heavier medium coat. That should give you a nice glossy look.
Old Nov 17, 2010 | 11:05 PM
chicotunner07's Avatar
Azure pearl?
i acctually just painted my front lip myself buying aerosol colormatched paint from here
http://www.automotivetouchup.com/
bought the clear coat aerosol too and it was super easy to apply, maybe you can just aerosol the clear coat and save yourself the headache.
heres a pic to see the color match, it was spot on!
good luck!
Old Nov 17, 2010 | 11:45 PM
FlintLBC's Avatar
minter 66: Looks good, make sure you take some pics when they are on the car.
chicotunner07: thats clean, i actually wanted to paint a spoiler myself. How did you prep your lip before you painted it?
Old Nov 17, 2010 | 11:52 PM
user 7208230's Avatar
^x2 would love to repaint my lip, got it used to it needs some re-finishing.
Old Nov 18, 2010 | 12:12 AM
Jon's Avatar
Jon
Moderator
Moderator
I may have to give that aerosol a try. My front lip needs a respray.
Chico, how many cans did it take for the front lip?
Old Nov 18, 2010 | 12:30 AM
the lip was new primered from factory
first i washed with dish soap, dried then used prep solvent
then used a fine scuff pad and rinsed and dried again
used prep solvent again
3 med coats of primer (bought from automotivetouchup.com)
4 med coats of base coat
and 3 heavy coats of clear coat
i came out really glossy, i had fine grit paper ready to wetsand and polish but its seriously not needed in my case!
Jon, i used half can of primer, 1 full can of base coat (had a tiny bit left), 1 full can of clear (had about enough for half a coat)
Old Nov 18, 2010 | 12:32 AM
also, 15-20 minutes in between coats, weather was 80* and 45-55% humidity (a rarity in south florida) and i did it in my garage
took me about 6 hrs with all the waiting in between coats.
Old Nov 18, 2010 | 04:52 AM
FlintLBC's Avatar
cool, thanks a lot for the prepping steps
Old Nov 18, 2010 | 02:07 PM
minter66's Avatar
So get that "frosty" look all over the car, then a bit less "frosty" medium cover and then go heavy? Does the frost give the clearcoat something to "bite" on and stick?
Excellent insight, if I bomb the clearcoat again this weekend, I'm doing that or having a professional shop do it.
Originally I was just going to toss in the towel, but I figure try until I run out of paint/clear.
Old Nov 18, 2010 | 04:33 PM
Joyride's Avatar
Yeah it gives something to stick too. I think the hardest part is to learn when to stop putting on clear before it runs. Its hard but after practicing you get it. I still eff up my clear coats on occasion.
Old Nov 19, 2010 | 08:25 PM
deekny's Avatar
wow, that is some good painting. the most i have done is to use a spray can from www.touchuppaintonline.com to paint a sideview mirror. how much was your spray gun?
Old Nov 20, 2010 | 01:28 AM
killatc171's Avatar
also, 15-20 minutes in between coats, weather was 80* and 45-55% humidity (a rarity in south florida) and i did it in my garage took me about 6 hrs with all the waiting in between coats.
your lip turned out good didnt know you painted it yourself. nice job on the paint. i didnt the same with my whole rs1 lip kit. but i used duplicolor perfect match paint for autozone. best aerosol ive used other then www.automotivetouchup.com.
and like chico said you could use the clearcoat from there, there clear coat is good for aersol clear. or you could use the clear coat i used on mine turned out really glossy as well. i just used duplicolor perfect match clear coat. also great stuff.
Old Nov 20, 2010 | 01:56 AM
thanks!
ive used automotice touch up before, but for small pieces, like mudflaps, and trims, never tried painting such a large piece, i honestly could not be happier, and i spent 40 bucks on 1 can of paint, 1 can of clear, and 1 can of primer, how can you beat that! lol
Old Nov 20, 2010 | 01:59 AM
Jon's Avatar
Jon
Moderator
Moderator
Thanks for the info Chico. I'm gonna order some supplies this weekend. I was going to wait on the GFX rear but if I can paint it myself I may go ahead and get it.
mw1957
Mar 16, 2015 06:00 PM
Archangel1183
Feb 24, 2015 09:51 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
