Mid Pipe Rattling
Old Dec 3, 2010 | 09:24 PM
tcrs20's Avatar
Default Mid Pipe Rattling
So i got my tsudo mid pipe put on and it started rattling against what im guessing is a heat shield or something but its is rubbing against that and the bolt thats on it....would it be a bad thing to take that off and if so any ideas? i was gonna bend the arms that the hangers are on but the wields dont look to good on it and i was afraid by doing that they were gonna break.
Old Dec 3, 2010 | 09:28 PM
TCnightrider's Avatar
Team Scionara
all you have to do is take something and indent the bolt in and it should stop rattling
Old Dec 3, 2010 | 10:35 PM
beandip007's Avatar
Seems to be a problem with some of these, when I hit a good puddle my rattles like crazy, and I have done some work to give it clearance.
Old Dec 3, 2010 | 10:46 PM
tcrs20's Avatar
lol indent? what is that
Old Dec 4, 2010 | 01:08 AM
Team Scionara
take something and hit the bolt so it bends up a little to make room so it doesnt make no sound
Old Dec 4, 2010 | 01:28 AM
tcrs20's Avatar
oh alright. ill try that tomorrow
Old Dec 4, 2010 | 05:39 AM
Mouse's Avatar
Just my 2 cents in dropping in on this thread... in all my years of custom car building, it's always better to find a part that works right than to simply resorting directly to "hit it, make a dent and that should work" method. Unless that's the only way to make clearence for something to fit right for an aftermarket or non-standard/ custom fab'd part.
Old Dec 4, 2010 | 10:43 PM
tcrs20's Avatar
what would you sub jest doing?
Old Dec 7, 2010 | 08:40 PM
diego1103's Avatar
I'm running a tsudo and I had the exact same problem. I ended up taking it to the shop and turns out the pipe is not welded to spec. I had the guy cut it and basically rotate the front section of the pipe and re weld it. The guy did a great job and after that it bolted up beautifully. I also had him weld in a second resonator but anyway , tsudo's pipe basically doesn't fit well.
Old Dec 7, 2010 | 08:47 PM
FlintMica2005's Avatar
put on my midpipe 2 weeks ago and its vibrating on the cross member. im taking that off and i feel like theres another noise coming from what seems to be the heat shield also by the spipe area. gonna try and fix it this weekend
Old Dec 7, 2010 | 10:51 PM
tcrs20's Avatar
haha i went the cheep rout and hit the bracket that the bolt that was rubing against the resignation and hit it with a hammer and bent it in a little and it stopped it from happening all the time now its just when i hit a pot hole or a dip in the road
Old Dec 8, 2010 | 03:42 AM
RoboCop's Avatar
Take the black cross bar off. It will stop the rattling. I have yet to hear the rattle since I did this more than 3 years ago.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
ScionLife Editor
Sep 16, 2015 10:00 PM
