WTB - xB S/C Parts
WTB - xB S/C Parts
First I know this is wrong place, I do not have enough posts to put it in the PPC section, so please excuse me. Also going to have a lot here, hope you do not have a.d.d.
I have a '10 xB. I recently bought a S/C from a member on here, but sans parts. I have a parts list, and most of the part numbers I need and I am trying to find them. I am asking for help to put this thing together. Know any shops with xB s/c parts laying around? Have some in your garage? Your buddy got boxes of goodies in his basement? Send him my way! I need basically every part right now minus the s/c, and the intake box. Some of the parts I need cross over from the tC.
I will list the Toyota part number here (Some are the same for the tc, they start with a 2 instead of 5)
All start PTR41-
xB/tC
21052 Oil Feed T Adapter
*21054 Bypass Valve
*21057 Crank Position Sensor Wire Harness
*21059 Oil Feed Assy Hose
*21160 Oil Pan w/Return Tube
21061 Crankshaft Bolt
21062 Idler Pulley
21163 Fuel Injectors
*21069 O-Ring
21080 Exhaust Heat Shield
21084 Rear S/C Mtg Bracket Assy
xB specific
52081 Inlet Manifold
52084 Inlet - Outlet Hose Kit
*52085 Oil Return Hard Line Assy
*52086 Convolute Wire Harness Loom Wrap
52088 VSV By-Pass Hose Kit
52089 Clamp Kit
52090 Idler Pulley Hardware Kit
52094 Rubber Inlet Pipe Kit
52095 Battery Tray Kit
52096 General Hardware Kit
52097 Clutch Line Kit
52098 MAF Pipe Kit
52099 Discharge Hose Kit
Any help is appreciated.
*Update, if it has a asterisk by it I no longer need it. I got some parts in this week.
All start PTR41-
xB/tC
*21054 Bypass Valve
21062 Idler Pulley
*21069 O-Ring
xB specific
52089 Clamp Kit
52098 MAF Pipe Kit
just so you know. from what i have heard and read. the SC is grossly inferior to the cost of a bolt on turbo kit. so you might be better off selling the SC parts and just getting a turbo kit from decsadent for about 3k. Good to go self install.
ColonelSanders85
12-09-2020 09:44 AM
scionlife
04-16-2003 05:13 PM
