Help with C.E.L. codes...
Old Feb 7, 2011 | 09:02 PM
ThePriceofGas's Avatar
Default Help with C.E.L. codes...
Hey guys new to this forum. I have a 2008 XB with about 43,000 miles on it. The check engine light came on about 1 month ago and I reset it by unhooking the battery hoping it was nothing. It stayed off for about 2 weeks but has come back. I pulled the codes today and they are:
P0354
P2237
P2238
I have e-mailed a local dealer to see what they have to say about it. Any insight as to what is going on? I half way consider myself a shade tree mechanic and would like to fix myself if possible. Any help is greatly appreciated.
Old Feb 7, 2011 | 09:12 PM
AAG's Avatar
AAG
DeepSouth Scions
Coil pack(s) and 02 sensor failures from what I found out using google.
Old Feb 8, 2011 | 04:52 AM
CIONIDE's Avatar
Time for a new wiring harness?
Old Feb 8, 2011 | 06:05 AM
eight08customs's Avatar
is that what it is.. mines came on but never pull the codes yet..
It sputters for a while than it runs ok.. than the light goes off. I get back in the car and CEL and Traction light on.. and here we go again..
Wiring harness issue?
Old Feb 8, 2011 | 06:33 AM
CIONIDE's Avatar
https://www.scionlife.com/forums/sho...d.php?t=174166
https://www.scionlife.com/forums/sho...d.php?t=158956
https://www.scionlife.com/forums/sho...d.php?t=197895
https://www.scionlife.com/forums/sho...d.php?t=194800
https://www.scionlife.com/forums/sho...d.php?t=154124
is your friend.
Old Feb 8, 2011 | 11:29 AM
None of those shows any codes anywhere in them. So not sure what you are trying to say. I am not new to forums and I do search but random threads do not help.
edit:
Unless you are referring to the stuttering above your post then it makes a little more sense.
Old Feb 8, 2011 | 11:32 AM
I have read about the wire harness problem. Is this a job that I could do myself? I have not found a part number for it yet. Does anyone know it? Would be nice if it was only a coil pack and an O2 sensor but I have my doubts after reading about the wire harness last night. Would the wire harness be covered under the 5yr 60k mile engine and powertrain warranty?
Old Feb 8, 2011 | 03:39 PM
CIONIDE's Avatar
Originally Posted by ThePriceofGas
edit:
Yes, I was referring to the post above mine.
Yes, it would be covered.
Old Feb 8, 2011 | 08:44 PM
Just got off the phone with a service rep. Going to take the car in Thursday morning for them to run the codes themselves. He said a C.E.L. may or may not be covered under the power train warranty. I asked him about the TSB for the wire harness and he said he was not familiar with it and that some TSB's are covered under warranty and some are not. I guess I will find out more Thursday. Now I just need to drive the car and get the light to come on again. I reset it with the code reader the other day and he said it is best if the light is still on.
Old Feb 15, 2011 | 03:39 PM
The light finally came back on and the wife took it to the dealer today. He said the #4 coil pack needs replaced but he said it is not under warranty. I had her to ask about the powertrain warranty and he told her that anything that is touched by a liquid is not covered under warranty. I then informed her to get in the car and drive away. They never mentioned anything about the code for the O2 sensor that I got. I still think it is probably a bad wire harness. They wanted 2-$300 to do the repair. I have not seen the list but she said he was going to print everything out. She mentioned that he wanted to do some fuel cleaner process that cost over $100. From everything I have ever read that is one of the biggest rip offs they hit you with.
Anyways looks like I will be replacing the coil pack myself, anyone on here ever done it?
Hope29
Jun 2, 2012 08:22 PM
Infiz
Sep 9, 2009 01:14 AM
phederico
Regional - Desert & Salt
14
Nov 12, 2008 07:54 PM
drjohnson36
Nov 4, 2008 06:26 PM
jct
21
Mar 10, 2005 12:27 AM
