question about transmission drain and fill plugs
Old Feb 16, 2011 | 08:55 PM
ToolishTc's Avatar
Default question about transmission drain and fill plugs
are there washers on these and if so do they usually need changed when i change my gear oil? are they they same size as the oil plug?
thanks
Old Feb 16, 2011 | 09:24 PM
Syldrin's Avatar
they are not the same size not even close. as far as washers i cannot remember if there is a crush washer on them
Old Feb 16, 2011 | 09:30 PM
GammaTNT's Avatar
there are washers on the drain and fill plugs. Don't not over tighten them. One member was leaking tranny fluid after over tighten the drain plug. sorry i don't know the size.
Old Feb 16, 2011 | 09:33 PM
SquallLHeart's Avatar
do not need to be changed, and definitely not the same size as the motor oil drain plug
Old Feb 21, 2011 | 09:02 PM
ToolishTc's Avatar
thanks for the replies. as soon as the weather breaks i'll put your info to use.
Old Apr 8, 2011 | 12:15 AM
ToolishTc's Avatar
an update, and a couple of notes
the drain and fill plugs are both 24mm, and make sure you use a very shallow socket or you will not be able to fit a ratchet on the drain plug.
when you open the drain plug, be prepared for a rush of gear oil. it comes out with a lot of force and flies into the control arm and splashes everywhere.
i filled up with a pump and the fill hole on the side of the tranny to avoid removing the reverse sensor. overall, it was a really easy job.
Old Apr 25, 2011 | 01:06 AM
Tc3340's Avatar
How much fluid will I need when I do this myself? I'm going to Change it as I dont think it's been done since the car was brand new.
Old May 10, 2011 | 05:37 PM
BadDudeTC3's Avatar
You'll need 4 quarts of fluid when filling the transmission. Are you Auto or Manual?....Reason I ask is because I just changed my Auto trans fluid and I had to use a 10mm hex head to unscrew the drain plug....I'm sure its a lot different on a manual. Like the previous post stated, be ready for oil to gush out as soon as turn the drain oil! Also I had to go to the dealer and pick up the WS type transmission fluid because that's what my 07 tC used.
Old May 10, 2011 | 07:27 PM
Tc3340's Avatar
I'm manual.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
rjjone2
Feb 19, 2015 05:33 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
