Scion tC 2G ICE & Interior In-car entertainment and electronics...
2 Quick Questions...
Old Mar 17, 2011 | 10:08 PM
DJHACK's Avatar
Question 2 Quick Questions...
Ok,
First off, I was looking to add some bass back into my ride. I will do the install tomorrow but have two questions:
I have the base radio, does it come equipped with phono plugs behind it to run my amp?
Next, any recommendations on grounding points, and which wire to tap for the switched 12v source of the amp? Any help is greatly appreciated!
Old Mar 17, 2011 | 10:14 PM
WellesleyScion's Avatar
I cant remember if the OE radio has the pre-outs, I dont believe it does though.
Use the remote wire lead on the back of the radio, for a ground use a rear seatbelt screw.
Old Mar 17, 2011 | 11:28 PM
DJHACK's Avatar
Thank you,
Looks like I may need to use a line out converter then. I was trying to avoid that for sound quality but my options may be limited...
Old Mar 17, 2011 | 11:40 PM
DJHACK's Avatar
Update:
Just pulled my deck on my break to find...eureka! We have phono plugs. I'm excited. Wellesy, any idea as to the color of the remote wire coming from the radio? I wish I had a diagram.
Old Mar 18, 2011 | 12:42 AM
The solid white wire on the big harness
Old Mar 18, 2011 | 02:18 AM
DJHACK's Avatar
Thank you!
Old Mar 18, 2011 | 05:16 PM
Scion Canada's Avatar
SCION CORP
PM me if you need anything else!
Old Mar 18, 2011 | 08:59 PM
DJHACK's Avatar
Ok, found out my switch wire was actually a yellow one on the middle harness. Now I have full power to the amp. My Phonos are all plugged in, as is the box, and I am still not getting any sound. Do i need to bypass an internal amplifier to get the phonos to work? I had this setup in my last car and it worked perfect. I'm so confused!
Old Mar 19, 2011 | 01:13 AM
noisy1eh's Avatar
you will need to turn on the sub RCA's on. if you have the std pioneer radio hers a link http://www.scion.com/assets/pdf/audi...neer_Audio.pdf
Old Mar 20, 2011 | 03:51 AM
DJHACK's Avatar
Thanks! Works perfect now
Old Apr 5, 2011 | 03:20 PM
Cemented's Avatar
To get to the rear seatbelt bolt for a ground does that panel just snap off also?
Old Apr 5, 2011 | 05:36 PM
noisy1eh's Avatar
The back seat has 2 bolts very accessible by just lifting the rear cargo mat and at the front is a small carpet section that is removable from just behind the seats. there you will find 2 seat bolts.
Try them they will make life easy unless you have already run wires to the other..
Old Apr 5, 2011 | 06:56 PM
Cemented's Avatar
Did you have to sand anything?
Old Apr 7, 2011 | 01:47 AM
Jericho941's Avatar
I am using one of those bolts for a ground right now and didn't need to sand anything.
drgonzo92
14
Apr 24, 2019 07:27 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
BlingSlade
Sep 5, 2015 08:52 AM
mc1114
Aug 12, 2015 02:07 AM
goatbelly
Jul 12, 2015 10:13 AM
