Painting Parts Question.
Old Mar 19, 2011 | 10:50 PM
Wavechaser's Avatar
Default Painting Parts Question.
I was in the process of ordering a set of custom grills for my TC, but I realized the only thing really driving me crazy about the OEM was the giant Scion Logo in silver on the grill.
So instead of spending $60+, I decided to go to the auto store, get some flat black spraypaint, and just do the job myself.
I bought Dupli-Color Flat Black Automotive Paint. I was reading the label several times to see if I needed to buy like a primer or clear coat or something to make sure the color stayed once sprayed on. The directions said nothing about doing this, so I assumed it was designed to be used by itself.
So I went home, pulled out my top grille, and followed the directions, doing 2 light coats, spaced by 10 minutes each, then a heavy wet coat. It looked absolutely beautiful, but the can did say while you could handle it after 2 hours, it would take days to completely set.
A week later, and I can run my hands on the grill and gather black residue. Albeit, it's a small amount, but it doesn't appear to be staying on.
Did I miss a step? Should I have gotten some kind of finishing coat?
If this went well, I was going to work on painting my TC waterfall flat black as well, but I'm definitely not going to touch it until I figure out what went wrong here.
Any feedback is appreciated, thanks!
Old Mar 19, 2011 | 11:42 PM
TRD05TC's Avatar
did you prep it at all, scuff/sand and clean it?
Old Mar 20, 2011 | 12:01 AM
Wavechaser's Avatar
I did clean it really well, but no, there was no scuffing or sanding. I assume that's where I went wrong.
Old Mar 20, 2011 | 01:40 AM
DigitalPro's Avatar
Flat black spray is like chalk, no protect coating at all. I did the same with my TC OEM grill emblem and after a few days I saw alot of stone chips....yuk. Try spraying again and maybe apply a clear coat to seal it, though it will be shiny.
Old Mar 20, 2011 | 04:31 AM
ryun84's Avatar
Resand and Plastidip?
Old Mar 20, 2011 | 06:28 AM
Wavechaser's Avatar
I may try to do another couple coats, then throw on a clear coat. The thought of sanding off the layers I originally applied as well as the factory ones, is not enticing.
Either that or just suck it up for a 50.00 Ebay set... Meh.
Old Mar 20, 2011 | 09:11 AM
Aurora's Avatar
Black plastidip. It's a piece of cake and it eats road rash for breakfast!
Old Mar 20, 2011 | 09:35 PM
Spicy_McHaggiz's Avatar
More coats+clear coat won't make it stick. The lack of scuffing and cleaning afterwards is why its not staying on. Adding to it will only make it worse.
my06tc
Jun 25, 2015 12:18 AM
BrokenTC2
Jan 27, 2015 03:32 AM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
