e manage problems
Old May 17, 2011 | 02:56 AM
nismosr24's Avatar
Default e manage problems
my car runs like carp when my e manage is pluged in but when i un hook the e manage and run the stock ecu it run perfect.so if any one knows anything to help.i need it befor i go crazy
Old May 17, 2011 | 02:57 AM
thendawg's Avatar
Need alot more info...
Eman Ult? Or blue?
Fuel injectors being used?
Any CEL's?
Mods?
Old May 17, 2011 | 03:13 AM
nismosr24's Avatar
emam ult with 440cc injecters(greddy turbo kit) ,lite weight crank pully,throttle body spacer, 2.5 s pipe,greddy evo 2 exhaust .cel light p0351 when its pluged in but gone when its not.well hears what happend a few weeks ago my carbon fiber engine cover foam melted to my coil wires some how. but i fixed all of that i thought went to start it and its running rough like it was missing no power.so i got the idea to plug in the stock ecu and it runs great but i no that the car needs the e man run the right fuel and stuff. so thats where im at
Old May 17, 2011 | 03:40 AM
thendawg's Avatar
That code is for a coil malfunction - Im thinking you couldve possibly shorted (and damaged) one of the ignition drivers in the ultimate. Connect the EMU to your notebook and when you connect to it, see if it shows you any errors, itll pop up a box when you connect in the software if there are any errors on the EMU.
Old May 17, 2011 | 03:00 PM
paul_dezod's Avatar
Scionetics
KAD
Where the jumpers correctly set in the EMU and is there a valid base cal loaded into the unit as well?
Old May 17, 2011 | 07:40 PM
myr6goesfast's Avatar
Is this vehicle tuned with the emanage?
Old May 17, 2011 | 07:41 PM
nismosr24's Avatar
yes it has the base map on it the jumper are right because be for the hole issue it ran great. and i dont have the support software to hook it up to my note book.it has never been tuned only the base map from greddy
k1114
43
Mar 1, 2023 03:08 AM
Marganne
Apr 3, 2015 06:52 PM
D_Roke
Mar 31, 2015 05:37 PM
idriveanxa
Mar 8, 2015 12:03 PM
