HHow too. Aam fuel rail . Looking for installation
Old Jul 28, 2011 | 09:43 PM
dguzzardo22's Avatar
Default HHow too. Aam fuel rail . Looking for installation
Has anyone installed one or has instruction how to ?
Old Jul 29, 2011 | 12:22 AM
thendawg's Avatar
Its pretty straight forward. Remove the stock rail and replace. Only thing is, I dont know if the stock dampner/feed line will bolt up to it. Its designed for cars making alot of power that require a return system and an upgraded feed line. What kind of mods do you have?
Old Jul 29, 2011 | 12:27 AM
thendawg's Avatar
I just looked. it looks like you can use the stock feed/dampner with that rail. So all you have to do is unbolt the stock rail, disconnect fuel line, unbolt the dampner from the stock rail, remove injectors, than reverse to install the aem rail. Another tip is to pull the EFI relay than crank the car before beggining to remove the stock rail - this will discharge any fuel pressure in the system and keep the mess to a minimum.
Old Jul 29, 2011 | 03:26 AM
skinnayyy's Avatar
Team Scionara
yes. it will keep your cabin smelling like gas after you start driving again. yes. i know this from experience
Old Jul 29, 2011 | 12:46 PM
It also comes with the fuel regulator and fuel return line
Old Jul 29, 2011 | 03:19 PM
I'm looking how to set up the pressure reg and return line
Old Jul 30, 2011 | 02:06 AM
Does anyone have this ?
Old Aug 2, 2011 | 06:10 AM
Bump for instructions on proper return lune mount and fuel press reg psi and line running .
YooItsJay
Dec 2, 2015 08:13 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
