HHow too. Aam fuel rail . Looking for installation
Its pretty straight forward. Remove the stock rail and replace. Only thing is, I dont know if the stock dampner/feed line will bolt up to it. Its designed for cars making alot of power that require a return system and an upgraded feed line. What kind of mods do you have?
I just looked. it looks like you can use the stock feed/dampner with that rail. So all you have to do is unbolt the stock rail, disconnect fuel line, unbolt the dampner from the stock rail, remove injectors, than reverse to install the aem rail. Another tip is to pull the EFI relay than crank the car before beggining to remove the stock rail - this will discharge any fuel pressure in the system and keep the mess to a minimum.
cid_mcdp
Jan 5, 2015 02:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
