Goin Back to stock help...
Old Aug 2, 2011 | 01:25 AM
sebbyxtc's Avatar
Default Goin Back to stock help...
Im goin back to stock from boostin for a while and im havin some trouble with the intake part. Also the white nipple on the maf sensor thing where does that go. Im having trouble putting the intake back on the throttle body because it wont budge to go on idk if im missing something.
Old Aug 2, 2011 | 02:55 AM
sebbyxtc's Avatar
Anyone??
Old Aug 2, 2011 | 03:14 AM
amp0804's Avatar
Slide that clamp a little further away and use your finger to rub grease on the inner part of the rubber so it glides over the tb easier.
Old Aug 2, 2011 | 04:35 AM
pyroman131's Avatar
If you want better luck, use a vise grip to loosen the metal clamp so that you can easily slide the rubber hose onto the throttle body. Releasing the vise grip then will lock the metal into place for you. Bada bing.
The grease is also a great idea, too. But I don't know what kind you'll want to use. I went with the aforementioned method.
Old Aug 2, 2011 | 10:49 PM
syberspyder's Avatar
I think you have the vacuum line in the wrong place. It should go to the white port, I think where you have is just a mounting bracket.
It should go: throttle body>vsv switch>to hard line
I'm not sure if it matters which line goes to what on the vsv though.
Old Aug 2, 2011 | 10:56 PM
sebbyxtc's Avatar
So it should go from the thtottle body to the white nipple ?
Old Aug 2, 2011 | 11:07 PM
sebbyxtc's Avatar
Can anyone put in their input becsuse when i removed that factory line and replaced it with that line(it had been t tapped for my boost gauge) it had been on that black nipple. Just not sure what the white one is for
Old Aug 2, 2011 | 11:52 PM
Just checked myself, got me curious when you said you had it set up differently.
I have it white to hardline, black to tb. The spot you have it is just a mounting post, that post is actually a separate piece that is connected to the vsv with a screw.
Also there is a diagram under the drivers side of the hood that shows this vac line.(without the colors or ports though)
Old Aug 3, 2011 | 12:08 AM
sebbyxtc's Avatar
Can you or someone take pictures if its not too much to ask for?
Old Aug 3, 2011 | 12:10 AM
thendawg's Avatar
You need to connect the line to the white barb, the black piece is only a mounting point.
Old Aug 3, 2011 | 01:16 AM
I am not stock(SC), but what I explained works.
Old Aug 9, 2011 | 03:45 PM
StreetSweeper's Avatar
Pm me ur number ill send u a pic
Scionxa180
Jan 14, 2015 12:30 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
