Scion tC 2G Aero & Exterior Aero parts and exterior dress items...
How to prevent low beams from coming on when flashing highs?
Old Sep 26, 2011 | 06:28 PM
johnmk's Avatar
Default How to prevent low beams from coming on when flashing highs?
Present behavior:
During the day, when low beams are off, if you flash somebody, the car flashes lows and highs together.
Desired behavior:
Flashing turns on high beams only.
Any idea how to make that happen? My main concern is to preserve the fullest possible lifespan for my HIDs, and I'm aware that on/off cycles have an appreciable negative impact on lifespan, particularly for HIDs.
Separately, how would I stop the low beams from flashing when the alarm comes on, but otherwise preserve all other functions of my low beams?
Old Sep 26, 2011 | 09:12 PM
buckeye25osu's Avatar
During the day, when lights are off don't "flash someone" by using the brights. Instead flash them by cycling lights on off quickly. This would use low beams only. Serves the same function and is only milliseconds slower.
Not sure about the alarm.
Old Sep 26, 2011 | 10:02 PM
vaxc3's Avatar
umm... I don't think that works.. he wants to "prevent" the sudden on/off of low-beams to prolong his HID's life... typically HID's are low-beams...
I personally would recommend not to mess with those electrical connections... its cheaper to get replacement bulbs and ballasts...
Old Sep 26, 2011 | 10:30 PM
biglilsteve's Avatar
The low-beams really also turn on when you pull the blinker lever in?? I always thought it was just the brights!...
How often do you flash others and use your alarm though? Enough for this to really be worth it?
Old Sep 26, 2011 | 10:48 PM
Jon's Avatar
Jon
Moderator
Moderator
I'd like to know this as well. I've wished the tC had flash-to-pass ever since I've had my 1G. If constant power could be provided to the high beam relay then it should work. Since right now it's contingent on the low beams being on.
Maybe something similar to how people rewire the fogs to come on with the parking lights. Except use a constant source like an ignition wire.
carid
Jan 8, 2015 11:33 AM
Pkupman_77
Dec 30, 2014 09:10 PM
paul_dezod
Scion tC 1G Wheel & Tire
Dec 10, 2014 06:46 PM
eric_m
79
Mar 17, 2013 12:21 AM
xBsquared
Nov 2, 2003 09:50 AM
