OSRAM LEDs
Old Nov 2, 2011 | 05:15 PM
fongyz's Avatar
Default OSRAM LEDs
Maybe Garage1217 or some LED mods can help me...
Found some OSRAM LWT6SC LEDs.
Details:
White PLCC-2
Optical Efficiency: 22 lm/W
Viewing angle: 120
Voltage : 3.0 Min, 3.6 typ, 4.1 Max
Luminosity: 1000 mcd
I plan to use these LEDs for my instrument cluster and HVAC .
Question, will these draw too much power / operate fine like other PLCC-2 LEDs that other sellers use? How about running a resistor to amp up the intensity?
I bought these cuz of the brand name, Osram ;) we all know Osram for quality OEM lighting. hehe
Old Nov 2, 2011 | 07:57 PM
torqueTc's Avatar
OSRAM for sure is top notch. I used to run OSRAM euro bulbs on my Porsche 944 turbo.
Old Nov 2, 2011 | 09:09 PM
fongyz's Avatar
Indeed, I just need to know what kind of resistors and regulator I need to make these work?/....
Old Nov 25, 2011 | 04:44 AM
LEDmod's Avatar
You can see my guide and it will show you which resistor to use..
https://www.scionlife.com/forums/sho...d.php?t=105994
You can buy just the resistor and voltage regulator from my web site..
http://store.ledmod.com/index.php?ma...products_id=73
Old Dec 1, 2011 | 08:21 PM
fongyz's Avatar
@ LEDMOD, I'm not sure bout the specs (especially typ fwd voltage) on your LEDs are , but I am using the same resistors as on your site, and my osrams still do not appear to be running near the spec typ voltage of 3.7v I will do a voltmeter check soon.
*Edit: I also see various no-name "super white" LEDs that run at 3.3v, and the resistors on your site may work better for that, but I would probably have to go to 270ohm resistors for the maximum output on these Osrams*
Old Dec 6, 2011 | 04:39 PM
LEDmod's Avatar
If you your LED Is rated for 3.7v you'll need to lower the resistance more so you'll get more current
But 3.7v is pretty high number for PLCC type LED and it will run much hotter....
hondajt
Dec 14, 2015 12:54 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
Subaru86
Sep 14, 2015 12:43 PM
SJMiller
Sep 12, 2015 06:33 PM
