Head unit connectors w/ photos
Hi, i'm trying to install an aftermarket sony head unit. I found the appropriate wiring harness to utilize two of the connectors that went into the stock oem head unit (the right two in the photo), but i'm not sure what the other two little white ones are for and what to do with them (on the left). Also, the antennae cable isn't seating in the back of the new head unit. I would really appreciate some help, thanks everyone.
You would only use the 2 on the right. If you waned to you use the other 2, one is for the steering wheel control and I forgot what the other one is for. i think its for the stock upgraded audio system not sure on that one though. And as for the antenna it should plug right into the aftermarket radio. if it doesn't you might of plugged it into the wrong spot.
wiltonhall
Jun 23, 2025 10:09 PM
sithscripter
Mar 31, 2004 04:02 AM
sithscripter
14
Feb 25, 2004 12:00 AM
