sunroof will not shut. 1/4 inch gap in the back
Old Apr 5, 2012 | 05:30 PM
daimonmustdie's Avatar
Default sunroof will not shut. 1/4 inch gap in the back
i greased my wind deflector tracts with white grease, and i reinitialized my sunroof and windows several times but the sunroof will not fully close all the way leaving a huge gap in the rear. any other suggestions? thanks
Old Apr 5, 2012 | 06:05 PM
mxyooji's Avatar
any weird noises ? your track may be having issues.....off track and misaligned..
Old Apr 5, 2012 | 06:43 PM
no weird noises. opens smoothly, closes smoothly, except for that last step (when the sunroof becomes flush with the roof)
Old Apr 6, 2012 | 06:47 AM
sciontc_mich's Avatar
have you checked the pivot points of the wind deflector? there are two up front, and there are pivot points on the arm that pushes up the front deflector. Wondering if maybe those are binding causing an issue..
now if that's fine, the other thing to look at are the two pivot points that "vent" the sunroof panel, those could be binding as well.
Old Apr 8, 2012 | 11:54 PM
where exactly are these pivot points?
Old Apr 9, 2012 | 03:54 AM
when you vent the roof, you'll see them that lift up the backside of the sunroof. was just wondering if those were binding. My thinking is that if the sunroof can't pull that pivot point down, then the roof wouldn't be able to move into its fully closed position. and that would leave that rear sitting up above the roofline.. sort of like when you "vent" the sunroof without opening it fully.
edit: they are massive 3/4" - 1" wide metal scissor looking pivot points. you can see them from the rear of the sunroof.. let me know if you need more detail.. wish i could find a pic of it..
Monkey343
Scion xD Suspension & Handling
Nov 10, 2016 02:07 PM
jcraff3
Feb 20, 2015 11:41 PM
2006sciontcva
Scion tC 1G Aero & Exterior
Jan 7, 2015 01:51 PM
EthanAJS
Dec 21, 2014 10:16 PM
smilygo
Nov 1, 2003 11:26 PM
