Free "Basic" enclosure designs..
Old Apr 11, 2012 | 02:50 PM
abraves4410's Avatar
Default Free "Basic" enclosure designs..
I'm offering up some free enclosure designs if you guys want them. I'll provide a sketchup image with full dimensions and post it up here. This is not a box building service or anything like that. I simply make the design, hook you up with the dims,
and you build it on your own. I've designed and built quite a few enclosures for myself, am MECP certified (like that even matters) and can provide plenty of references over on RealmofExcursion if you guys have any doubts.(my username is cxa0897 for those who are curious)
I'm only offering MDF designs, not dealing with fiberglass since getting dims for it is a pita, and ill offer sealed/vented enclosures. I can also provide 4th order and parallel tuned 6ths, but they are time consuming, so I'm not making any promises there since i work and am in school.
Here's a few examples of what I've done recently over on ROE, and this is pretty much what you can expect to get from me
Very basic vented enclosure design for a Mojo 15
Slightly more advanced vented enclosure design for 2 SA 12s
A compact box ill be using when my SA8s arrive
etc etc.
I just enjoy making these, and it never hurts to build up a portfolio of enclosure designs, so let me know what you need. I run all of my designs through modeling software first and then make the design from there based on the max dimensions given to me and/or preferences
I am not charging for these drawings, and do not provide any box building services or anything like that. I do not have the time to build these, so don't even bother asking. I barely have enough time to build my own enclosures.
____
Old Apr 11, 2012 | 02:55 PM
if you do want a design i need the following information:
car its going into
either max dimensions, or preferred dimensions
if its going into a trunk make sure to measure the trunk opening and let me know that also
model and quantity of subs
power being supplied
types of music you listen to
whether you want spl, sql, or sq
any other preferences you have, tuning, sub/port orientation etc
a link to the T/S parameters would be awesome too, so i dont have to waste time searching for them ;)
if you do not know what tuning you want or orientations ill make my best judgment on it based on the other info you provide. I will also let you know if i feel your preferences are poor, i.e. requesting a 47 hz tuning is not a good idea.
Old Apr 11, 2012 | 06:05 PM
Cisco_TeamShogun's Avatar
I know these designs and the process is very time consuming, and any design program is expensive too. So I thank you for providing this service for free to the ScionLife community.
another great example of passing it on - giving a tree
Thanks.
so to confirm this, if I say I am looking for a sub box to fit behind my rear back seat in the tC, to fit 2 8" subs and one 6.5" and I don't want it to be taller than 10" you can draw dimensions to match? if so this is cool!
(I don't want a sub box with those dimensions, I was just throwing numbers out there)
__________________
Old Apr 11, 2012 | 06:27 PM
surely. dont know why you want two 8s and a 6.5 but i can make it work lol
ive gotten all the programs for free, so i didnt have to shell anything out for this, but it can be very time consuming like you mentioned. a real basic box is a matter of a few minutes, but once things go beyond a basic rectangle it starts to take a lot more time.
Ill try to stay on top of this thread, if you put something up and i dont respond within in a day or so, send me a pm. if i dont respond to that, it probably means im not doing these anymore
Old May 23, 2012 | 06:14 PM
bump, finally wrapped up the spring semester, so ive got a little more free time to play with.
to make this a slightly more worthwhile post, here's a design for what ill be putting in my tc within a week or two
series 6th, should pretty much kill anything from 25-60
Old Jun 12, 2012 | 03:57 PM
hnyuH_divaD's Avatar
Still offering services? Im about to pick up a RE Audio seX 10, stupidest name ever.
let me know if you need the specs
Old Jun 12, 2012 | 04:26 PM
re is easy to dig up, i can get them. ill post one up here or pm you within a few days. ive got a good amount of free time now
Old Jun 14, 2012 | 12:13 AM
works out pretty much on par with re's recommendations. 1.3 tuned at 33. should do well with sub up port back
Old Jun 14, 2012 | 08:33 PM
Looks great man, thank's a lot! I trust you, so I'll build shortly after i get my sub.
Old Jun 15, 2012 | 12:53 AM
the 45 is optional, but it will really help with reducing noise and help a little bit with spl since it smooths air flow in the port.
Old Jun 15, 2012 | 09:01 AM
Is there anyway it can be smaller? I forgot what the minimal vented was, these cars have no trunk space =(
Old Jun 15, 2012 | 09:52 PM
Min was around 1 cube. It will sacrifice a bit of spl, but I can make it a more compact square if you want to preserve more of the hatch. I'll draw that up tonight after work.
You could also just do a rear seat delete to fit your enclosure like I had to :p
Old Jun 16, 2012 | 01:32 AM
this one is a tad more complex, but will save a ton of room for you
sub firing back, port firing towards the passenger side.
the port is going to require the two walls, and a top piece which will be L shaped to cover it, which will run all the way to the front wall.
dimensions would be as such
Old Jun 16, 2012 | 01:49 AM
That looks awesome man, i'm excited to get rid of my 2 ed 10s in the 1cf sealed i built. lol
Old Jun 16, 2012 | 05:17 AM
misfits138's Avatar
your designs look awesome, thanks for offering up this service. I was wondering about the dimensions for an enclosure that would go in place of the stock sub on a tC1, a stealth box I think they're called. It would be a 12" kenwood kfc-w12ps I believe. http://www.kenwoodusa.com/Car_Entert...fers/KFC-W12PS
Old Jun 17, 2012 | 01:55 PM
i honestly have no idea what the dims of the stealth box/stock sub are and ive never even seen one so im not able to help much there. stock systems are
Old Jul 6, 2012 | 05:25 AM
Not perfect, but came out pretty good, Cant wait to carpet it!
Old Aug 6, 2012 | 12:52 PM
bump. still doing these.
diva, you ever get that box hooked up? looks like it came out fairly well. ive seen much, much worse attempts ;)
Old Feb 1, 2020 | 11:02 AM
ZrBleedGr's Avatar
Default Hello
You still do cut sheets ? Thanks
randomsuper
Sep 6, 2009 02:11 AM
MikeC
Mar 20, 2007 05:30 AM
gsmithcon
Nov 2, 2006 10:37 PM
davedavetC
Scion tC 1G ICE & Interior
25
Apr 8, 2006 05:58 AM
Notacop
May 29, 2005 07:17 PM
