grounding for amp in rear of xb..
Old Mar 31, 2005 | 03:17 PM
tbone587's Avatar
Default grounding for amp in rear of xb..
Now that my whole rear area, including the rear seats is stripped down to bare metal for dynamat, i want to find the best possible ground for my amplifier. I see on both of the rear panels there is factory grounds there being used. Would it be a good ground to use that. Before I took everything apart I was using one of the black mounting brackets that held the back rests into the floor.
Old Mar 31, 2005 | 04:33 PM
Cockpit_XB's Avatar
Admin Emeritus
thats what i used for my system, but its up to you where you want to use to ground your system.
Old Mar 31, 2005 | 04:50 PM
SuperCrunchyAction's Avatar
I use one of the rear seat bolts for my ground.
Old Mar 31, 2005 | 09:17 PM
tbone587's Avatar
i just want to use the most effective ground.. i dont know if the rear seat bolts are the best ground..
Old Mar 31, 2005 | 11:00 PM
kkawana's Avatar
i used one of those bolt locations that had D-ring bolted to it.. there were 1 on each side under the spare/storage location.... just sand the paint off real well and good to go....then again.. since im not using the sparetire/storage peices anymore and my box takes up that space and hides wires... but if ya keep the spare/storage spaces... dunno if that place will work for you
Old Mar 31, 2005 | 11:43 PM
khaye's Avatar
well whatever you use, make sure you strip the paint to bare metal(like kekai said)...this way you get a better ground
Old Mar 31, 2005 | 11:53 PM
Scion05BOPxB's Avatar
Kekai.. any pics of your box? I want to build my box for 2 12s in that rear area as well. Also, where did you mount your amps?
Old Apr 1, 2005 | 08:37 AM
kkawana's Avatar
not yet...been tryin to hold out till the cover(cosmetic ) is done...but i'll try takin a pic or 2 tomorrow and show the "raw" box..... and will post them up here
Old Apr 2, 2005 | 11:00 PM
tbone587's Avatar
i think i found a good ground to use.. its an already drilled hole on the floor in the rear of the xb, that should be much better than what i had..
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
missing_image
Feb 7, 2015 07:18 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
bluxb
Oct 16, 2003 03:58 AM
