Keyless Entry Programming?
Old Jul 6, 2012 | 03:06 PM
Lonely_Raven's Avatar
Default Keyless Entry Programming?
Long story short, I was robbed and someone has my keyfob for my 2005 xB. The thieves already used it to open up my car and steal anything not nailed down.
I need a new keyfob, and it needs to be programmed to the car. I know I've seen directions somewhere on how to do that, but I'm coming up short searching here...I keep finding references to the guide, but no guide.
Can someone help point me to this guide? I'm looking to pick up a replacement keyfob through Sparks or eBay ASAP.
I spoke with two dealerships in my area, and one of them said they wanted $225 for a new keyfob including programming! F-THAT!
Help!
Old Jul 6, 2012 | 04:00 PM
I've been searching all over the web, and found this...it almost sounds like a joke, but another page backed this up.
Scion XB (2004-2007)
1. Driver's door open, key removed from ignition switch.
2. Within 5 seconds, insert and remove key from ignition switch twice.
3. Within 40 seconds, close and open driver's door twice.
4. Insert and remove key from ignition switch.
5. Within 40 seconds, close and open driver's door twice.
6. Insert key into ignition switch and close the driver's door.
7. Switch ignition ON and OFF once to program a remote while
retaining the original codes. Switch ignition ON and OFF twice
to program remote while erasing the original code. Switch ignition
ON and OFF three times to check how many remotes are currently
registered or five times to erase all registered remotes.
8. Remove key from ignition switch.
9. System should now lock and unlock vehicle. Once, twice, or five times
depending on which mode has been selected. Once to four times, slowly,
to indicate how many remotes are programmed.
10. Within 40 seconds: Press and release LOCK and UNLOCK buttons simultaneously.
11. Within 3 seconds: Press remote LOCK or UNLOCK button.
12. System should now LOCK and UNLOCK vehicle. Once to confirm registration,
twice to indicate programming has failed.
13. Within 40 seconds, repeat step 10 to program additional remotes.
Up to 4 remotes can be programmed.
14. To exit programming mode, open driver's door.
Old Jul 6, 2012 | 08:17 PM
Caprice0083's Avatar
Help!
Word! That's a new security system and more than likely a better one you have in the Box now!
yupinmytC
22
Jul 27, 2024 07:08 PM
Wrencher
May 24, 2018 10:15 AM
Denzel
Oct 14, 2015 10:15 PM
umnitza
Sep 1, 2015 08:06 PM
Armystrong
Aug 31, 2015 08:19 PM
