06 xB uphill battle..
Old Jul 12, 2012 | 12:44 PM
Ldiablo85's Avatar
Default 06 xB uphill battle..
Morning America. I can't figure out what is wrong with my 06 xB 151,000 miles - I changed the plugs and all coils - oil and air filter - but still has two issues makes funny jingle , or maybe not jingle - more like metal on metal noise in the front bottom driver side under engine and also when I first start car in the morning.
Engine sounds and feels like its going to turn off, like it's on some kind of respirator fighting for it's life - when I put it in drive and tap the accelerator it takes a few seconds to actually push the car, slows down bad going up hill? I hope it's not tranny??? Could it be time for the timing belt?
Please help
____
Old Jul 12, 2012 | 01:51 PM
JIMXB's Avatar
some things u did not mention:
Have u ever changed the $15.00 PVC valve which helps with engine respiration?
you have high milage
Did ever do a good cleaning of your fuel injectors with any aftermarket products such as SeaFoam etc?
Change your fuel filter located under the hatch spare tire area?
Good Luck.......
Old Jul 12, 2012 | 02:07 PM
Ldiablo85's Avatar
no sir i have not changed pvc , and have not cleaned fuel injectors ...would that be something i could do on my own with tools from my "average person tool box" lol - parts and cleaning foam dont sound pricey . i was told by autozone and advance that to replace fuel filter i had to replace the whole fuel pump ? is that not true ? i also forgot to mention "trac off" "VSC" and check engine lights are on ... im scared , i was reading yahoo answers and some people are saying it will be the timing chain ..$$$
thanks so much for helpin out
Old Jul 12, 2012 | 03:45 PM
Caprice0083's Avatar
Here is a link to the manual for the xB, it shows you how to remove everything JIMXB mentioned to you.
https://www.scionlife.com/tech/manual/?manual=xb04_0001
Old Jul 12, 2012 | 04:21 PM
Ldiablo85's Avatar
nice carprice i appreciate that, i have alot of work to do this weekend - - anybody know how i can find out if it is my time chain ? -
Old Jul 12, 2012 | 04:31 PM
JIMXB's Avatar
Well, since you are not taking your high mileage car to a mechanic to find the problem. Just my 2 cents others may not agree. I would at least start with the cheap simple needed high mileage car maintanance:
1. change the $15.00 PVC valve
http://autos.yahoo.com/maintain/repa...ques079_1.html
2. check all engine air/vacuum hoses if loose or cracked.
3. Here's the DIY on cleaning the MAF sensor
https://www.scionlife.com/forums/showthread.php?t=160320
4. I would do this before I use a fuel system cleaner.
DIY xB Fuel Filter Change $60.00, which is right under the rear seat cushion https://www.scionlife.com/forums/showthread.php?t=93840.
4. Clean your fuel system thru the gas tank with professional BG 44K Fuel
Cleaner about $30.00, some say it is alot better than SeaFoam.
Now about the Check Engine, VSC, Trac Off- something to read to get u started
https://www.scionlife.com/forums/showthread.php?t=163405
Keep us posted on what + how you did to solve your problem.
Good Luck........
If there is an Autozone near you, have them pull the codes for the Check Engine light. That will tell almost exactly what you're dealing with. They do that service for free.
Old Jul 12, 2012 | 05:29 PM
Ldiablo85's Avatar
yes i will keep you all posted ! this is sooo cool - !!!!!!!!!!
Old Jul 20, 2012 | 04:54 PM
JIMXB's Avatar
http://www.youtube.com/watch?v=vAbGydNgaYk
Good Luck........
PS if you would like to purchase BG 44K Fuel System Cleaner it's hard to find + only sold to car dealers or auto repair shops. You find it on ebay or from where i buy it http://www.autobahnpower.com/products.asp?recnumber=542. I just bought 6 cans for my 3 cars + to save$ on shipping. You get a 11 oz can for 20 gal gas tank.
Good luck. Keep us posted on your fix.
GROC80
Jun 4, 2013 05:00 PM
hardlucktattoo
25
Jul 31, 2012 11:25 PM
code3mmc
Jun 29, 2009 04:17 PM
Diluvium
Jul 12, 2008 04:43 PM
Socalrider
Aug 23, 2007 11:56 PM
