Air fuel ratio engine connection
Old Oct 20, 2012 | 07:38 AM
Sleeper_TC's Avatar
Post Air fuel ratio engine connection
Ok, lately ive installed my gauges in my car, so far i only have my boost gauge working properly but i still need my oil pressure and air fuel ratio! everything is wired through the car and on and working but those 2 are not wired yet!
for the air fuel i know that it connects to the o2 sensor on the header inside the engine but not quite sure what wire to connect it to. theres 3 wires, a green white and black! any suggestions or tips on that?
for my oil pressure i believe that i gotta dump out my oil that is currently inside my car in order to connect a part of it to the motor. what is the next step to do or what can i do to properly get my oil pressure running?
Old Oct 20, 2012 | 01:20 PM
my06tc's Avatar
what gauges do you have..brand
Old Oct 21, 2012 | 02:30 AM
Sleeper_TC's Avatar
i have a boost, oil pressure, and a air fuel ratio and its from glow shift
Old Oct 25, 2012 | 06:40 PM
my06tc's Avatar
not to familar with glowshift,or there wires...but usually,the wideband sensor,goes on the s-pipe,would need a,additional bung installed,if not already have one,right beneath,the 02 sensor,the oil gauge,you can t it off the head off the stock oil sensor,or get a glowshift oil filter sandwhich,and used that for oil pressure
Old Oct 25, 2012 | 07:50 PM
Roller_Toaster's Avatar
Is it a wideband a/f gauge?
Old Oct 25, 2012 | 08:22 PM
TheQuietThings's Avatar
The reading you receive from the O2 sensor will not give you an accurate reading because it is a narrowband sensor. It will essentially be a dummy gauge. If you are looking to make the needle move around, just hook it up to any wire that will give you a voltage of between 0 and 3v. If you want something accurate you will need a wideband sensor.
Old Oct 26, 2012 | 05:34 AM
Sleeper_TC's Avatar
@my06tc isnt there an o2 sensor right there on the header too? yeah thats what me and my friend was plannin on doin with the oil, t it out but not quite how its gonna fit with my supercharger though!!!!
@Roller_Toaster yes its a wideband a/f gauge
@TheQuietThings well i actually want it to read and work properly instead of it just bouncing up and down though
Old Oct 26, 2012 | 05:36 AM
A narrow band taps into your existing 02 sensor, while a wideband usually requires welding a bung onto your header/downpipe for the wideband's very sensitive 02 sensor.
Old Oct 26, 2012 | 02:39 PM
Then you will need to buy a wideband 02 sensor.
Old Oct 27, 2012 | 05:11 AM
Spicy_McHaggiz's Avatar
There is an o2 sensor on the header, it's the MAIN one for the car. It's also not inside the motor. Anyways, if you want a PROPER read, you need a wideband o2 sensor installed in the S pipe. Then run the gauge to that. A properly reading gauge will "bounce" to an extent as your A/F ratio changes. Connecting to a narrow band will give you more a light show. This is what you are trying to do.
Are you turbo'd? And I hope you didn't pay too much for Glowshifts, their garbage.
Old Nov 3, 2012 | 07:20 AM
Sleeper_TC's Avatar
Post
[QUOTE-Spicy_McHaggiz]There is an o2 sensor on the header, it's the MAIN one for the car. It's also not inside the motor. Anyways, if you want a PROPER read, you need a wideband o2 sensor installed in the S pipe. Then run the gauge to that. A properly reading gauge will "bounce" to an extent as your A/F ratio changes. Connecting to a narrow band will give you more a light show. This is what you are trying to do.
[QUOTE-Sleeper_TC] oh ok and those are a bit pricey arent they? like the aem a/f ratio gauges! well i actually want an actual reading not a light show...
and actually my car is S/C and i paid like $80 for my boost and a/f guage
Old Nov 4, 2012 | 10:14 PM
deez's Avatar
Glow shift gauges? Ughhh! Send them back or throw them away. I've always had good luck with AEM gauges and Defi.
evolving_machine
Oct 21, 2023 01:16 PM
nightfox915
Apr 17, 2015 07:06 PM
joapy
Jan 27, 2015 03:26 AM
eric_m
79
Mar 17, 2013 12:21 AM
TheRedBox
15
Jul 9, 2006 04:08 PM
