aem intake = lower rpms?
Old Feb 15, 2004 | 09:25 PM
OC_Scion's Avatar
Default aem intake = lower rpms?
i was driving my friends xB the other day and he has the aem intake and i noticed that in 5th gear goin like 75 mph's his rpms were only at like 3000 - 3100.
now i dont have the intake and when i am at 75 mph, my rpms are at like 3900-4000.
are his rpms lower because he has the intake? or is my car just weird?
thanks
Old Feb 15, 2004 | 09:28 PM
Munch's Avatar
Does he have bigger wheels on his car, like 17,18,or 19's?
Old Feb 15, 2004 | 09:51 PM
OC_Scion's Avatar
no, he had the stock hub's on his
Old Feb 15, 2004 | 11:09 PM
BigOrangeXb's Avatar
Manual or auto? An intake can't change the rpm's at X mph. That's determined by 1st through 5th gears and final drive ratio in the trans. Different size wheels will change it, small wheels turn faster and big wheels turn slower at X mph.
Old Feb 15, 2004 | 11:36 PM
Rayman's Avatar
So if you have bigger wheels your RPMs will be higher because more power is needed? That would mean shorter engine life possibly? Hmmmm. Now I wonder if I should get 17s?
Old Feb 16, 2004 | 12:27 AM
kdanie's Avatar
RPM vs speed is a math function of engine speed, gear ratio and over all tire diameter (NOT WHEEL SIZE). I have 17" wheels and 215/45 tires on my Xa and they are .25" shorter in dia. than the stock tire/wheel combination. Not noticeable at all.
Power does not make a car cruise at a lower RPM, it does make it cruise with less throttle opening at the same RPM.
ken
Old Feb 16, 2004 | 01:32 AM
hnefrdo's Avatar
prolly going up a slope the time without the intake, so yer steping steeper and pulling the rpm up to maintain speed.
Old Feb 16, 2004 | 02:13 AM
Sorry, I should have said overall tire diameter.
A taller tire will turn less RPMs at a certain speed since it has to roll longer to complete 1 revolution. Think of it this way: If you cut a tire across at one place and laid it out a 225/50/16 tire would be longer than a 205/40/16 (just used those sizes as an example). If you look an www.tirerack.com at the specs page of a certain tire. It'll show you overall diameter and revolutions per mile for all the sizes offered.
Old Feb 16, 2004 | 04:07 AM
jackmott's Avatar
No, if the speedo says X mph the rpm will always say Y rpms in a given gear. uphill, downhill, or thrown off a cliff!
and bigger wheels will change hte ACTUAL speed, in a given gear at a given rpm, but NOT the indicated speed. Your speedo will just now be wrong.
Solowcal_tc1
14
Feb 27, 2024 06:23 PM
hampton1100
May 28, 2015 07:32 AM
Bobb_Todd
Jan 16, 2015 06:57 PM
Besk_one
12
Nov 17, 2003 10:29 PM
yanges
16
Sep 26, 2003 06:01 PM
