Correct Brake Bleeding Procedure????
Old Apr 8, 2005 | 09:42 PM
tlzook's Avatar
Default Correct Brake Bleeding Procedure????
I have new brake lines and "stuff" for my box...I will be bleeding the system with a "motive" power bleeder and need to know if the std. way of bleeding applies....right rear, left rear, rt frt, left frt,master......Thanks, SC
Old Apr 9, 2005 | 06:15 PM
jct's Avatar
jct
don't know what the motive power bleeder is...
but yes you should bleed 'em from the right rear, left rear, right front, left front, the master cylinder is not need if you didn't swap it out, if you did you should bleed the master cylinder frist (ie: bench bleed it) then bleed the rest normaly the way you do it
kmouse64
Sep 4, 2015 01:11 PM
bmxScion
Jul 23, 2015 12:07 AM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
blackpearlTC
Jul 19, 2015 04:55 PM
Tak16
Jul 7, 2015 05:45 PM
