Correct Brake Bleeding Procedure????
I have new brake lines and "stuff" for my box...I will be bleeding the system with a "motive" power bleeder and need to know if the std. way of bleeding applies....right rear, left rear, rt frt, left frt,master......Thanks, SC
don't know what the motive power bleeder is...
but yes you should bleed 'em from the right rear, left rear, right front, left front, the master cylinder is not need if you didn't swap it out, if you did you should bleed the master cylinder frist (ie: bench bleed it) then bleed the rest normaly the way you do it
