New wheels alternative HELP!
Old Apr 15, 2005 | 12:11 AM
ToBeeyach's Avatar
Default New wheels alternative HELP!
So I'm getting a widebody kit for my tC. Very sexy indeed. And along with it i'm getting a paint job. So now that i'll have wider fenders my wheels will have to come out wider to match. The car showing the kit off had wheels with an offset of zero so i'm using that as a guide.... anyway's my question is this: Is there an alternative way to bring my wheels out to match my fenders without getting new wheels? because everything is getting very expensive, very fast. If so, could you point me in the right direction?
Thanks in advance,
Tobias
Old Apr 15, 2005 | 12:42 AM
deep2k's Avatar
only thing I can think of are some spacers
Old Apr 15, 2005 | 01:44 AM
dex's Avatar
dex
the studs aint long enough in order to use the massive spacers hed need.
with a zero offset, and the same width wheel as factory, your already pushing the wheel out almost 2 inches. if the rims were wider (and i assume their alot wider) then its getting pushed out even more than that. if your gunna drop the cash into a wide body kit....dont cheap out when it comes to the rims. otherwise scrap the body kit and just get the rims if your going broke.
Old Apr 15, 2005 | 02:06 AM
ToBeeyach's Avatar
eeesh this sux. if i have to get new wheels, i'll def get wider ones and then new rubber to go with it.... this is turning into nearly an 8000 dollar project... and i don't suppose i'd find many used 18" or 19" wheels, 8 to 9 inches wide, with zero offset AND the right bolt pattern... STRESS
Old Apr 15, 2005 | 02:46 AM
TheBigGuyRy's Avatar
I know, this stuff can get so expensive, so quickly.
I suppose it's just a lesson for everyone to plan ahead...
Old Apr 15, 2005 | 03:55 AM
jrv2000's Avatar
I know you can get spacers for our car from H&R that are 25mm and come with new studs so you dont have to worry about that. So if you can find a rim that has a 25mm offset, the 25mm spacer will get you down to 0.
Old Apr 15, 2005 | 05:03 AM
taek's Avatar
www.jlinewheels.com =D custom forged
Old Apr 15, 2005 | 05:12 AM
BoomBox757's Avatar
DelMarVa
you can get longer studs, and some spacers come with them like the H&R I think it is
Old Apr 15, 2005 | 06:19 AM
hahaitzskippy's Avatar
nope.. no way...
need new wheels... studs... spacers...
Old Apr 15, 2005 | 06:27 AM
BoomBox757's Avatar
DelMarVa
yea I would say if your are going to get a wide body kit you should do it right and get the wheels
Old Apr 15, 2005 | 01:06 PM
tct's Avatar
tct
I am going to get spacers as soon as my car comes out from the body shop ....Wheeladapters.com can make custom ones for your car. I have 19x8s . I am going to get 2" spacers so it should sit flush with the new fender flares
Old Apr 15, 2005 | 09:23 PM
SupaWhiteTc's Avatar
I would put 10-12" wide rims on it. Thats my 2 cents. You can fit 10" on a stock TC so why not go bigger.
Old Apr 17, 2005 | 07:59 AM
krazykustomz's Avatar
You can use spacers or multipiece wheels with a custom offset. The wheelspacers are an adapter spacer.
The adapter bolts to the hub just like a wheel does and it has new studs for the wheel to mount.
I did this on my cougar to pushout the 20x9 axis wheels
oblivionlord
9
Mar 14, 2015 07:26 AM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
Mar 3, 2015 09:47 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
dgm458
Scion xD Drivetrain & Power
Dec 7, 2014 05:59 PM
