Rear Tail Light Fixture Removal
Old Apr 18, 2005 | 07:42 PM
alexw1's Avatar
Default Rear Tail Light Fixture Removal
Would someone please give a brief explanation on removing the fixture(s)? I have replacements and don't want to hurt anything going into it. Didn't see anything in the tech section. Thanks.
Old Apr 18, 2005 | 08:54 PM
alexw1's Avatar
Come on, this should be an easy one, I just want to avoid screwing anything up.
Old Apr 18, 2005 | 08:57 PM
Denstyr's Avatar
you need a 10mm socket. just remove the panels in the trunk. Then you feel 2 nuts, use the 10mm socket and preferably a small ratchet, to take the 2 nuts off. Then it's easiest to remove either the middle bulb or just the wire from the middle bulb. and you're done! switch them out, put the bulbs in and tighten the screws back up!
Old Apr 18, 2005 | 08:58 PM
Denstyr's Avatar
the nuts will be on both sides (over and under) of the middle (blinker) bulb
Old Apr 18, 2005 | 09:16 PM
SlickNick's Avatar
Then you feel 2 nuts...
I hope so !!!
I think he meant for instructions on how to replace the whole tail light housing, not just the bulbs.
Old Apr 18, 2005 | 09:18 PM
Denstyr's Avatar
that's how you do it. 2 nuts and some wires is all that holds the light fixture there!
xBSciontist
Jun 18, 2019 03:06 PM
TheTripleC
Jan 4, 2015 06:46 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
Slopoke21m
Oct 2, 2003 04:59 AM
randode
16
Oct 1, 2003 12:40 AM
