Remove shifter?
1) unthread you shift ****, just simply twist it off
2) in the rear cupholder of the center concel, remove the lil carpet square to unearth the screw holding it in place.... once the screw is removed, the front if the center concel just has 2 snaps to the floor
3) Then you'll see 4 bolts holding the white plasic shifter frame to the floor...
4) now there is a clip that holds the cable to the shifter, remove those and the cables should just pop off the shifter
5) now the cables will have a housing that snaps the outer sheath of the cable to the shifter from, just simply lift to snap those out
these directions will make more sence to you as you do it.... they're just hard to visualize, plus i'm a bad explainer..haha
Threequalseven
Aug 26, 2015 04:24 PM
Latexbullet
Jul 21, 2015 04:02 PM
