Cant remove road oil from silver paint!!
Old Apr 20, 2005 | 02:04 AM
lardo5150's Avatar
Default Cant remove road oil from silver paint!!
I purchased some turtle wax bug and tar remover for the bugs and road tar, that works great. But I have some brown spots, VERY light, that looks like soda was spilled on the car. Except the spots wont budge with anything, and seem to be deep in the paint. They are near the tires where oil would get shot up. Can anyone recomend a compound, spray, or anythng to get rid of these marks. Thanks.
Old Apr 20, 2005 | 03:16 AM
Scion05BOPxB's Avatar
did you try WD-40?
Old Apr 20, 2005 | 12:03 PM
lardo5150's Avatar
WD-40??? Wont that eat the paint or ruin the finish?
Old Apr 20, 2005 | 01:44 PM
grizzly_choppers's Avatar
It's possible that this is what they call "rail dust". It's a product of these cars riding in train cars across the country. I'm not an expert on these kinds of things, but we get this complaint from customers every now and then. Just take it to the dealership and see what they can do. If it is rail dust, they shouldn't charge you.
-Alex
Old Apr 20, 2005 | 03:42 PM
lardo5150's Avatar
I will do that, also, is it a possibility of it being from my Tire Wet spray?
Old Apr 20, 2005 | 03:51 PM
lardo5150's Avatar
I was speaking with someone here at work, they stated that the Tire Wet, if it touches the paint, it will soak in and stain it a light brown????? And you cant get it out!!!!!!!! The spray is Black Magic Tire Wet.
Old Apr 20, 2005 | 06:07 PM
Certain cleaners are really bad for paint, I know that much. I don't know specifically about the one you used on your tires, but I do know that the tire dressing we use in our detail department doesn't affect paint at all (it gets used pretty liberally). I believe we use the Malco brand (but it could be the Car Brite).
Maybe give the company 800# a call and see what they have to say about the situation.
-Alex
Old Apr 20, 2005 | 10:13 PM
Before I started using Orange Peel (like Goo Gone), I used WD-40 to remove dealer decals and such from cars. It will remove the wax, so you'll have to reapply.
Old Apr 20, 2005 | 11:58 PM
jbo's Avatar
jbo
I used to detail cars and it could very well be from the tire wet which can be a real @#$?% pain. There still may be a way to get the lil spots off but you will need to take it to a pro. Then if you still use the tire shine just make sure you wipe off as much of the excess as possible. good luck
Old Apr 21, 2005 | 12:11 AM
TheScionicMan's Avatar
Use a clay bar. Mother's makes a nice kit. It's really easy and if it's on top of your paint, the clay will pick it up.
Old Apr 21, 2005 | 01:27 AM
lardo5150's Avatar
I will try all these suggestions, thanks everyone. Just have to wait till it quits raining.
Old Apr 22, 2005 | 06:26 AM
xScionB's Avatar
i have the same problem on my xB but the mothers clay bar system didnt work for me.
Old Apr 29, 2005 | 11:52 AM
SCI_TC_GUY's Avatar
That's because the clay bar isn't for stains.....it's for imbedded particles of dirt in your paint.....it will lift them out and make your car feel smooth like glass....
Old Apr 29, 2005 | 03:37 PM
shorberg's Avatar
take it to a professional. if you havn't been able to clean it yet, you may ruin your car by doing something stupid. take your car to a professional detail place. there is probably one at your dealership.
Old Apr 30, 2005 | 09:15 PM
CBSIMONSEZ's Avatar
I would try the WD-40 first. This will not hurt your paint. Shoot it on, let it sit for just a minute, then wipe off. You may have to use a little elbo grease, just make sure you have a clean cloth, as rubbing hard will cause scratches if there is any dirt on the rag. Follow with a soapy solution, rinse, then reapply wax.
If WD-40 doesnt work, then try a clay bar. Follow directions on box.
If this still doesnt work, then you need to take it to the dealerhsip and have them work on it. That is the whole reason for the clear coat, to protect the painted finish underneath.
Old May 7, 2005 | 08:35 PM
Sciond's Avatar
Use olive or corn oil and forget the other ideas
Old May 7, 2005 | 09:03 PM
littleblackbox's Avatar
a product that you may want to check into is Klase All in One cleaner, I think this will be just the thing you need. It is a very light polishing/cleaning product that should take care of most of the surface imperfection. It is really a chemical cleaner that cleans the paint and leaves a little bit of protection, not that much thou, so any sealant or wax should be used afterward. This will leave your paint super smooth, and best of all you can use it on ANYTHING, glass, plastic, wheels, anything that needs a good cleaning. Hope this helped some
my06tc
Jun 25, 2015 12:18 AM
lunchbx05
Dec 29, 2014 07:53 PM
minter66
Dec 15, 2014 01:45 PM
nacy333
44
Oct 4, 2009 11:18 PM
Opr8r
20
Feb 25, 2004 11:29 PM
