my tire was punctured
Old May 2, 2005 | 02:18 PM
jaewon223's Avatar
Default my tire was punctured
my tired was punctured last saturday and i removed the foreign object. it was a small piece of metal, but shortly afterwards the low tire pressure light came on. i have to keep refilling air cuz the pressure keeps dropping. my friend told me to get that tire patch thing. anybody got more info? looked it up online didnt find much
Old May 2, 2005 | 02:20 PM
ack154's Avatar
You're better off taking to somewhere to have it repaired. It's usually pretty cheap, but better than using any Fix-a-Flat or something - b/c then you can't repair the tire.
Old May 2, 2005 | 02:30 PM
PonyTc's Avatar
there is a really good green slime type thing, it will last you quite some time, BUT it is good to go get it patched. the patch should be less than 10 bucks
Old May 2, 2005 | 02:39 PM
matt_a's Avatar
Don't use Fix-a-Flat unless it's an emergency. That stuff really gums up the iside of a tire and rim. It's a mess for a tire shop to deal with. If you have a slow leak, just go to a local tire shop and have it fixed. It won't cost much (under $10) and won't take long.
Old May 2, 2005 | 02:51 PM
jaewon223's Avatar
ok thanks everybody
Old May 2, 2005 | 03:18 PM
epitek's Avatar
where is the leak btw? if its in the side wall, i dont think they can patch it up, or can they still? i got a flat once, and they said they couldn't patch it because it was located on the side wall... now that i think of it more.. i think i got butt raped on that one.
Old May 2, 2005 | 03:22 PM
ack154's Avatar
Did they at least give you any lube?
Ya, I think you're right, the side wall ones are pretty much shot... if it was just a nail or screw in the tread or something, that's usually the easiest to repair.
Old May 2, 2005 | 03:45 PM
epitek's Avatar
oh... they lubed it up alright.. so much that they gave me a tire with the wrong dimensions!! i had to get another tire after that, but i kept that one as a spare.
Old May 2, 2005 | 06:37 PM
JasonH's Avatar
You're not supposed to use Fix-a-Flat (or similar products) in any speed-rated tire. Since our tires are Z-rated, you definitely don't want to use it.
Old May 2, 2005 | 06:46 PM
Mindcage133's Avatar
You don't want to use the green slime stuff either. it's more for biks and lawn mowers. read the bottle "not recommended for use above 70 mph"
Old May 3, 2005 | 12:21 AM
vanberge's Avatar
most placec (like sears) can use this thing that is half patch, half plug... It works great.
I had to do it on my previous car, 94 intrepid.
They sell "do it yourself" plug kits like at walmart... but those don't work that well in my experience.
Go to sears, get it patched/plugged
Old May 3, 2005 | 12:44 AM
EnderSavesTheDay's Avatar
Please let us now how things work out.
Old May 3, 2005 | 03:57 AM
terra_tC's Avatar
If your planning on getting it patched, take it to a tire shop and get it properly volcanized.
I one had a key puncture and get stuck in my tire, out of all wierd things, and that is waht they did...works great now.
Old May 3, 2005 | 03:59 AM
The_Instigator's Avatar
Good to know the tire pressure monitoring system works properly though huh?
Old May 3, 2005 | 04:03 AM
Eiso's Avatar
yeah right! haha! Get it fix at a local shop dude! This kinda money needs to be spent when this thing happens
Old May 3, 2005 | 04:19 AM
ale_mama's Avatar
Gawd mine had a screwdriver in there , dont ask how but I had to get a brand new tire :dead: I tried to keep the old one but it was no good, It had a patch but since i was going to go out of town that guy told me it wasnt safe.
Old May 3, 2005 | 04:50 AM
woodstock's Avatar
haha... i can't resist... i would really like to know how you got a *screwdriver* stuck in your tire
Old May 3, 2005 | 04:56 AM
TurboMe's Avatar
i got a flat early this month and i patched it myself. Spray soapy water to find the leak if u dont know where it is.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
carid
Apr 14, 2015 02:18 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
