white parking lights
where can i purchase white parking lights? these are the ones that are an inch away from the low beams. these bulbs are giving a yellowish color to my luminic UV bulbs.
Heres some results i came up with.
http://www.xenonvalot.com/ledwedgebulb.html
the above is in europe so im sure shiping would be pricy, but they do have blue versions of these lights, i wonder... what would blue look like behind that yellow glass, probably crappy? yeah?
http://store.racinglab.com/piaa1.html
heres a place in CA. Blue and White.
Lab above seems to have found cheaper ones, good job!
I dont know if its the best idea, but I use LED's in those. Got em from www.superbrightleds.com. They are..for lack of better term...superbright.
https://www.scionlife.com/forums/viewtopic.php?t=67066
see this thread for info. he's using the blue led's but superbrightled's and autolumination sell the "super white" as well.
no, the bulbs melt the led housing if they headlamps get too hot. some people have said that their led's have melted. others have had no problems at all. if you put in led's for that spot, you should probably keep an eye on them.
if your low beams run too hot, then you'll need to get incandescent bulbs instead. if you're looking for super white incandescnets for the parking lights (194 bulbs), look here: http://www.cardomain.com/item/PIA19168
Originally Posted by dmxsoulja3
I thought someone said that the LED bulbs melt the housing?
Originally Posted by intrepid design
are #194's the same for, say, the license plate light?
i heard that LED's are cooler as well. and since i have Lumanics installed as headlights, and people have been talking about them melting things, im going to have to research with is a hotter bulb to reduce the risk of melting.
I went with raybrig R130's. They are a 194 with a super white look that match my hyper white lumincs perfectly. They are $12 a pair here http://store.racinglab.com/raywedbulpla1.html
I'm looking at some of these LED bulbs from http://autolumination.com and was wondering if anyone has them and how they work. I have the luminics pure blues and the stock bulb gives them a yellowish glow that offsets the blue too much. I wanted to go with a blue bulb to go there, but i dont know how the LEDs will work and if they are going to fit ok...
Inazuma
20
May 3, 2023 01:58 AM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
carid
Jan 8, 2015 11:33 AM
