New amp install - dumb question
Old Jun 17, 2005 | 08:16 AM
dslroxx's Avatar
Default New amp install - dumb question
Please help this total car audio noob. I am installing an amp for the first time and I have a question that may have an obvious answer - I just don't know what it is. The manual says, and I quote,
"Connect one end of an in-line fuse connector to the power cable. Connect the other end of the fuse holder to the positive battery post. Make sure the in-line fuse holder is within 18 inches of the battery. The fuse location will protect the system and the vehicle against the possibility of a short circuit in the power cable. Be sure to use a fuse and a fuse holder adequate for the application. Do not insert a fuse at this time. The maximum fuse rating for this amplifier is 2 X 20A. CAUTION! Replacing a fuse with one of a higher rating may cause damage to the amplifier and the vehicle's electrical system."
The amp has two 20A fuses in it. I understand that I am not to go bigger than that if I blow one. My question is what size fuse goes into the in-line fuse holder? Do I add the two 20A fuses to make a 40A fuse or do I use a 20A fuse? The fuse holder I have accepts 4GA cable input and 2x8GA outputs so I assume I have the adequate fuse holder. What size fuse?
Any help would be appreciated.
TIA,
Mike
Old Jun 17, 2005 | 10:01 AM
dos210's Avatar
most likely one of the fuses is a replacemant at least thats how most amps are so your probably only drawing 20 amps of current you would be more than safe running 8 gauge with a 40 amp fuse in the holder as long as your power cable doesnt go more that 17 feet
Old Jun 17, 2005 | 12:16 PM
neckbonenick's Avatar
the fuse holder usually comes with the wiring kit that connects your amp to your battery. If you used your own wire you should get yourself a nice fuse holder and a fuse. I believe they are normall 100 amp.
Old Jun 17, 2005 | 12:24 PM
Lonely_Raven's Avatar
I agree with this.
The fuse that's by the battery side (within 18" of battery post by the way), is to
protect the battery and the power cable it's connected to in case of short.
The 20A in the amp itself is to protect it's internals.
Old Jun 18, 2005 | 01:08 AM
dslroxx's Avatar
So I should go with a 40A at the in-line? Thanks a bunch, guys. After I get the install done I will send some pics out. I am putting the amp in the passenger side rear window in a rack I am making right now at work. I love getting paid to do my own personal stuff!
Thanks again,
Mike
missing_image
Feb 7, 2015 07:18 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
