computer chip???
Old Jul 25, 2005 | 09:39 PM
sciontC2006's Avatar
Default computer chip???
do those chips you see on ebay really work and give 20hp for only $20-30 or is it all BS.
Old Jul 25, 2005 | 10:10 PM
Obike's Avatar
All BS, use the search function and you'd see this.
Old Jul 25, 2005 | 10:34 PM
crayonBOX's Avatar
it's not even a "chip" it's a resistor that 'tricks' your MAF into thinking that the air in the intake is high density = cold air -- makes the injectors spew fuel
Old Jul 25, 2005 | 11:30 PM
TurboCustomz's Avatar
Actually, it tricks you IAT into thinking that the air is colder and therefore more dense. Your MAF measures the volume of air that passes through your intake.
Charles
Old Jul 26, 2005 | 12:46 AM
Diluvium's Avatar
Charles
oh yea, all that is true.. the chip does work but that is what it does, thus making it harmful to your engine. dirties up your fuel injectors...
put one in your scion tc and after 2months or next 2 oil changes, your technician will recommend you to do a COMPLETE FUEL SYSTEM CLEANING ($50) when he does an inspection (the chips are serious)... tho your car will pull harder then before and a much better throttle response...
and whats worst is having a short ram intake and aftermarket header... all that extra EXTRA heat sucked up and the IAT think its cold air, the short ram is NOT performing at its best. The heat is robbing too much power....
Old Jul 26, 2005 | 01:36 AM
Thrawn's Avatar
Charles
A temp. sensor is built into the MAF on the 2AZ.
Blunderbuss
Oct 8, 2015 04:56 PM
DryToast
Aug 4, 2015 02:59 PM
lookitsandrew
Jul 25, 2015 05:32 PM
herbn44
Jul 24, 2015 02:26 PM
