Optima Yellow Top Question
Old Aug 2, 2005 | 05:11 PM
BrEaK_AwaY's Avatar
Default Optima Yellow Top Question
Can you use both top and side terminals at the same time?
I will be using my top terminals for the cars ignition, audio, etc.
I want to use my negative side terminal to wire my grounding kit, is this possible to do? or will it cause damange to the battery?
If i do this, i will be using both top terminals, and only the negative side terminal (just wanted to clear it up even more)
Thanks!!
Old Aug 2, 2005 | 06:03 PM
Lonely_Raven's Avatar
The two are strapped together by a brass strip that's under
the yellow plastic. It's not an issue to use both terminals.
Just be careful in the future when you "disconnect the ground"
to service something...remember you have TWO grounds now!
Old Aug 2, 2005 | 06:37 PM
BrEaK_AwaY's Avatar
lol... yeah i should put a post it note on my battery to remember... cause i can see me forgetting that and shocking myself. thanks alot!
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
