Alarm/Remote start
Help! Has anyone had a problem with there door tigger light staying on when the door is closed. not bright but a dimm light shows after the door is close.you unplug the door tigger and it go's away, but then the door tigger don't work.
www.scionspecialties.net
Originally Posted by Evil Xb
There is a shorted/grounded wire in that circuit somewhere.
Another scenario is that you have a poorly designed alarm system which has the same characteristics as your door trigger (slight connection to ground) via circuitry.
Two solutions are as follows:
Yes a diode would be a typical solution but it is a 50/50 chance. Depending on the bias/tolerance characteristics of the diode you choose, it may or may not through the P-N junction eliminate the ground signal since diodes have a 0.7 V drop forward bias.
2nd solution is to use a relay. This is a more guaranteed solution as the ground signal required by a relay through the inductor is relatively high, therefore, your dim light effect will be eliminated because the relay requires approx. 100ma of current which in your case the weakened door trigger (-) signal can't provide that adequate signal with the door closed. With the door opened, a more solidified (-) signal will close the contacts on the relay and pass a strong (door trigger signal) to the alarm.
I would suggest on a 4 SPST pole relay to use this connection method:
Pin 85 - +12V
Pin 86 - Door Trigger (-)
Pin 87 - Ground (-) <-- don't use door trigger ground, use chassis ground
Pin 30 - Connect to Alarm door trigger.
Once again, this is assuming your door trigger is a (-) signal.
I am not trying to sound like I know it all, But being a veteran of 100 plus scion installs, 70 plus being my own brand, which has the same problem of the faint door open light, the diode cures the problem everytime, thats why I prewire the alarms with a 1 amp diode, to make my life easier.
The relay is geat for Isolating, but a diode only cost a few cents when bought in bulk and is alot easier t install. Use the diode and save yourself time and money.
Nor do I try to sound like that either. I hold your service record in the highest regards. I just offer assurance over chance in aftermarket installations that don't have the diode prewired. You could use a PNP transistor but thats a little more complicated.
I have used pnp& npn for isolating curcuits while not for low voltage dc, for simple automotive use the diode is easiest for practical purposes. You are also well versed, and you input is appreciated and needed on this forum. Thanks for the helpful input. Bill
mw1957
Mar 16, 2015 06:00 PM
cid_mcdp
Jan 5, 2015 02:45 PM
