OEM Toyota oil filter or aftermarket?
Old Aug 30, 2005 | 10:50 PM
sixtyspokes's Avatar
Default OEM Toyota oil filter or aftermarket?
Where (online?) is the best deal on OEM Toyota oil filters for the xB?
Also, are there any significant differences in the way OEM or aftermarket oil filters are constructed or perform? or is it basically just change the oil/filter at regular intervals regardless of name brands? There is such disparity in the prices of oil and filters... do you really get what you pay for (ie. K&N, TRD)?
Old Aug 30, 2005 | 10:58 PM
Max's Avatar
Max
There is a big difference in oil filters. Toyota OEM are actually really good. There are several comparisons online. Some of the cheaper filters stop filtering smaller particles after some time. I know FRAM really wear out after a simulated 2,000 miles in one test I read.
Mobil 1 filters are great as well.
Old Aug 30, 2005 | 11:09 PM
Max's Avatar
Max
Good reads:
http://www.nordicgroup.us/oil.htm
http://www.corolland.com/oil-filters.html
If I had to pick 5 out of the 10 as being the best, I would pick the Purolator PureOne, K&N, Toyota, Wix, and Purolator PremiumPlus as this group. Their prices start at $3.49 and go up to $9.94. Probably only the Mobil 1 filter is superior to the filters in this group
Old Sep 4, 2005 | 06:21 AM
jess_e_nuff's Avatar
Default oil filter
I know that Scion Norwalk,CA has oil filters for 6 bucks!
Old Oct 2, 2005 | 07:00 AM
zyzyx6969's Avatar
Big Sky Scion
$3.29 at Elmore Toyota, Westminster
Old Oct 2, 2005 | 01:11 PM
dexter_5000's Avatar
oem is not that much difference for what it is.
Old Oct 2, 2005 | 09:33 PM
fsr20det's Avatar
wrong. oem is the $h!t. they usually have a anti drain back feature so your oil lines remain full upon start up.
Old Oct 2, 2005 | 09:58 PM
jct's Avatar
jct
oil is kind of hard to drain out of the filter when it faces down
oil filter facing upwards i understand the anti drain feature
i use napa 1394 / wix 51394 brand oil filters
Old Oct 3, 2005 | 05:37 AM
IBJanky's Avatar
I use Supertech oil filters for all my vehicles
I've never had a problem with them
Excellent price too! Only $2.07/ea at WalMart
Old Oct 3, 2005 | 06:14 AM
AntwonePeterson's Avatar
What about the TRD ones?
Old Oct 3, 2005 | 09:21 AM
fsr20det's Avatar
it doesn't matter if there is oil in the filter. you want the oil in the lines. the filter prevents the oil from draining from the oil lines so you don't have to wait for the oil pressure to build up to lube the motor on start up.
Old Oct 3, 2005 | 10:07 AM
bB2NER's Avatar
Music City Scions
I say the brand of oil is more important that the filter brand. I prefer Mobil 1 oil and I've used Fram filters for 25 years with out a single problem.
What oil lines are you talking about? If the filter stays full you will have instant oil pressure upon start-up
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
rcflyer15
Dec 5, 2014 05:15 PM
eric_m
79
Mar 17, 2013 12:21 AM
arinvolvo
24
Nov 2, 2003 05:30 AM
