bleeding brake lines
Old Sep 4, 2005 | 09:37 PM
hunterUnknown's Avatar
Default bleeding brake lines
Does anyone know which order to bleed the brakes for the tc? I'm going to change the lines to SS and get new pads. Any help would be fantastic! :D
Old Sep 6, 2005 | 05:47 PM
Stoptech's Avatar
Usually you would bleed from the corner that is furthest from the master cylinder to the closest.
On the other hand, we've never encountered an issue from bleeding in the wrong order.
Old Sep 6, 2005 | 11:26 PM
yeah its what i hear, but a friend of mine says it matters so... i dunno. im just wanting to make sure im not out of the loop on some important info. thanks!
Old Sep 21, 2005 | 08:31 PM
well, as a followup, we bled the lines after putting in SS ones.
i dont know exactly how this ended up sucking so badly, but we did a lot of bleeding over and over to get the pedal to work acceptably again. its still on the weaker side, not nearly as reponsive as i'd like, but they work.
we tried the furthest to closest method first. didn't gain pressure once the car was on though. tried again, sucked again. tried a third time, doing a diagonal pattern: front-l, rear-r, front-r, rear-l. that worked out way better.
im going to try this bleeding business again, just a different way. apparently, you can leave the cap open on the reservoir and open one valve at a time, and just walk away and wait for air to rise up and escape. worth a shot. if it doesnt work, i guess im off to toyota.
by the way, ss lines rock. and so do porterfield pads.
Old Sep 21, 2005 | 09:03 PM
fastfrank04's Avatar
You can't bleed the Tc brakes yourself... You have to take it to a dealership and have them powerbled
Old Sep 21, 2005 | 09:07 PM
shinkuu's Avatar
which ss lines did you install?
Old Sep 22, 2005 | 12:07 PM
yokillr's Avatar
Please explain...
Old Sep 22, 2005 | 12:25 PM
I guess its the only way to get all of the air out of the lines... A guy on Clubsciontc.com made his own power brake bleeder. http://www.clubsciontc.com/modules.p...ewtopic&t=3058
I guess all it does is sends pressurized brake fluid in forcing out all of the air in the system.
Old Sep 22, 2005 | 02:22 PM
yokillr's Avatar
Ahhhhh. I see.
Someone should put that in the TECH section. Good info.
Old Sep 22, 2005 | 08:17 PM
I put in goodridge ss lines.
I'm pretty sure you can bleed brakes yourself. But I'm really considering taking it in anyway...
Old Sep 26, 2005 | 03:29 PM
sdparks's Avatar
Guys, check out my power bleeder DIY, now it is on ScionLife too. It should also be in the tech section soon:
https://www.scionlife.com/forums/vie...925&highlight=
ColonelSanders85
Nov 24, 2015 06:18 PM
cquencebrakes
Jun 23, 2015 09:42 PM
TotalChaos
Apr 7, 2015 09:02 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
kdanie
9
Jul 12, 2005 01:12 AM
