Pro Scan outcome..
Old Sep 7, 2005 | 10:47 PM
Kaeon's Avatar
Default Pro Scan outcome..
Well some people askedme to post the results. The software is off a little bit Im going to try to reduce the refresh rate so it can collect more data. and I have to get the exact weight of my car. That should reduce the numbers a little bit to a more accurate figure.
http://www.kaeon.net/album/albums/us...0001/test1.jpg
http://www.kaeon.net/album/albums/us...0001/test2.jpg
Those were done in 3rd gear with these settings
weight: 3370
drag coef: 0.320
gear drive ratio: 0.020340 (3rd gear)
and my tire specs 215/45/17
I have not had the car weighed yet. I just gave the weight a guess from the door jam weight plus me in it. The drag coef was found from a website so I don't know how correct it is. The drive ratio is from the program guessing the rate by running some tests so I don't know how correct this is either. Hopefully next runs goes down about 8 -10hp tq.
Car has DC Header, Axle back.
Old Sep 7, 2005 | 10:50 PM
engifineer's Avatar
Including a laptop bag with laptop and a bunch of equipment.. plus random other items in the car.
Old Sep 8, 2005 | 02:51 PM
matty-tC's Avatar
188ft-lb... i think thats a tad high
Old Sep 8, 2005 | 03:48 PM
OuterHeaven's Avatar
Ya that is a little high but remember the way the software works is if you over estimate weight then the numbers will be higher because it will think you are accelerating more weight at the same accleration. I have a g-tech and the higher the weight the higher the HP number but the lower the weight the lower the HP number. Also you can tell it pretty much is on the right track because the max tourque/HP are at about the same RPM numbers as the stock car. Anyways this looks to be about as accurate as my g-tech.
Old Sep 8, 2005 | 04:24 PM
Joe_Dezod's Avatar
So there you go! If you have no sound system, add your weight to the 2900lbs.
My Apexi RSM was pretty damn accurate. With AW header and a blitz ehxaust it said 152WHP.
Old Sep 8, 2005 | 04:40 PM
Kaeon's Avatar
LoL Did you not read the post or are you just commenting? I said I know its off and that the numbers should go DOWN a little bit...
Old Sep 8, 2005 | 04:50 PM
matty-tC's Avatar
just commenting
I'm not a fan of these mathetmatical horsepower calculators so i'll make this my last comment.
Old Sep 8, 2005 | 04:53 PM
Kaeon's Avatar
just commenting
Oh Ok
Old Sep 8, 2005 | 08:39 PM
lo_bux_racer's Avatar
just commenting
That's funny. All horsepower is calculated mathematically. The only thing you can measure directly is torque using either a known load (inertial dyno) or a brake (eddy current, water, hydraulic).
If your goal is to compare with other people using different devices, it's not going to be very good for a lot of reasons, but if your plan is to use it to measure changes you've made to your car, they work very well.
Old Sep 9, 2005 | 12:50 PM
aarontrini85's Avatar
this morning i finaly got around to trying out my rsm hp reader thanks to instructions from Joe
in 66 degree weather in a 3rd gear pull i made 154.8 hp that is with no exhaust right now (the injen was melting the bumper after the accident so i have to wait to put it back on) and basicly nothing else power wise done
Old Sep 9, 2005 | 01:35 PM
Lonely_Raven's Avatar
You are such a geek!!
But that's why we like having you around here!
Old Sep 9, 2005 | 01:37 PM
matty-tC's Avatar
he forgot to mention the pocket protector in the console
Old Sep 9, 2005 | 01:41 PM
BrEaK_AwaY's Avatar
truck weighting station... i wanted to do that on my last road trip... but i was running late =\
keep us posted on the new numbers when u change the software
Old Sep 9, 2005 | 01:58 PM
engifineer's Avatar
yeah I know.... I'm a geek
I was down at one of the shipping facilities for our company setting up a bunch of wireless warehouse equipment for a week. So I used one of the scales to see just how much it weighed. It is pretty handy to have a truck scale lying around to use
Old Sep 9, 2005 | 02:03 PM
engifineer's Avatar
I'm going to be working on that side of town (savage, MN) again here soon.. so I may try to check out the F/R ratio next time I play with the scale too
steeze69
May 24, 2021 02:57 AM
carid
Feb 10, 2019 10:46 PM
EVILDAVE
Sep 15, 2015 06:54 AM
JymmyTheSaint
Aug 26, 2015 03:44 PM
Araygoza100
Jul 18, 2015 05:53 PM
