Lower Strut bolts - are they eccentric or not?
Old Sep 27, 2005 | 04:57 PM
ASC's Avatar
ASC
Default Lower Strut bolts - are they eccentric or not?
Hey all,
I'm looking for a simple answer (couldn't find a straight answer using search!) regarding my question in the topic.
My xA will be delivered soon, and some TRD springs are on their way. I'm gonna use a spring compressor, and manually compress them since I don't have an air gun.
But before I pull the struts out, can someone tell me: are either of the bolts "eccentric"? If not, it makes it easy - just pull them. Otherwise, they should be marked so the drive to an alignment shop doesn't turn into a terror drive!
Oh, and another question: How tensioned/compressed are the springs when mounted in the strut? What I'm wondering is how much I need to wrench the spring compressors to relieve the tension before undoing the upper nut.
Thanks!
Al
Old Sep 27, 2005 | 07:19 PM
xB_Nutt's Avatar
The lower strut bolts are not eccentric. You don't need a spring compressor for disassembly or reassembly. Just point the strut away from you and take the top nut off and let her fly. Then have a friend compress the spring while you install the top nut when putting the new spring on. Make sure you loosen the top nut while the strut is still installed on the car.
Old Sep 27, 2005 | 08:31 PM
ASC's Avatar
ASC
egg-cellent. Thank you. Can't wait til this weekend.
Old Sep 28, 2005 | 12:16 AM
jct's Avatar
jct
safety first use the spring compressor's!!!
Old Sep 28, 2005 | 01:15 AM
xB_Nutt's Avatar
box-a-delic! You are very welcome. Good luck and check out this thread. Good stuff:
https://www.scionlife.com/forums/viewtopic.php?t=20769
I'm all about safety too, but I just personally did my xB and the amount of pressure stored in the front springs when you remove the top nut is very minimal. I have done other cars that absolutely required a spring compressor, but on the xb/xA you don't really need it. Not saying you can't use one if you want to be really careful...
Old Sep 28, 2005 | 02:30 AM
BlueBubble666's Avatar
I used a compressor on mine. It was kind of worth it, since I couldn't get the top strut bolt loose while it was on the car on one of the front assemblies. I just compressed the spring, got creative and it worked. So to get to the point, it was worth it in my situation.
Old Sep 28, 2005 | 03:46 AM
TXboxdriver's Avatar
lift, spring compressor and air tools
1 hour or less
nothing else is sanely safe
except the lift, jackstands are fine
get these bolts if u wanna adjust camber in the front
but don't ever forget about the TOE !!
http://www.specprod.com/PROD_DIR/PROD_APPS.HTML
Renike
Mar 1, 2015 10:40 PM
derekls
Scion xD Suspension & Handling
Feb 19, 2015 12:12 AM
hampton1100
Jan 2, 2015 08:13 PM
LVXB
10
Jan 8, 2004 08:33 PM
bryanrx7
Jan 1, 2004 09:53 PM
