check engine light is on
Old Oct 10, 2005 | 09:30 PM
jdmrider's Avatar
Default check engine light is on
I was on the interstate today and all of a sudden my traction control shut off and at the same time my check engine light as well as the vsc light came on.
Has anyone else had this problem? What could be causing this?
Old Oct 10, 2005 | 09:33 PM
O5Toaster-xb's Avatar
have you installed a new cold air intake or something that would effect the ecu ?? If so you need to remove the battery cable for a few minuntes and let it reset !
Old Oct 10, 2005 | 09:39 PM
jdmrider's Avatar
yeah I have a cai but it has been installed for a while now.
Do you still think that's the problem?
Old Oct 10, 2005 | 09:40 PM
Well maybe but probably not,,,,,,,,,But It may not hurt to try it ?
Old Oct 10, 2005 | 09:46 PM
turbochargedcobra2001's Avatar
I had the same thing happen to me I re-set the battery and about 90 miles later the problem happens again........vsc lite comes on as well as the check lite and trac control......i made an appointment for monday at the toyota dealer................
Old Oct 10, 2005 | 10:27 PM
jdmrider's Avatar
I have air ride on my xb could that have anything to do with it?
Old Oct 10, 2005 | 10:30 PM
dont thinks so since It happened to me as well and I do not have an air ride suspension............
Old Oct 10, 2005 | 10:42 PM
THE_DON's Avatar
Check the MAF...
-THE DON
Old Oct 10, 2005 | 10:44 PM
dgHotLava's Avatar
don't remove the battery cable, just pull the ECU fuse (under the hood fuse box, second 15amp from the firewall) this keeps your radio presets and clock...
Old Oct 10, 2005 | 10:47 PM
dgHotLava's Avatar
Default Re: check engine light is on
i had this problem...
the code came back as evap leak (small)
check the gas cap. take it off and put it back on tightly.
bottom line....unless you scan it for the code, this is just guessing.
Old Oct 10, 2005 | 10:49 PM
dgHotLava's Avatar
Originally Posted by THE_DON
Check the MAF...
-THE DON
if it is the MAF, it is not bad yet.
a bad MAF will not let the car run properly.
Old Oct 10, 2005 | 10:58 PM
stick_1NZ's Avatar
I'd do the fuse trick if I were you.
Old Oct 10, 2005 | 11:17 PM
chadfo's Avatar
Check the MAF...
-THE DON
To relieve a little tension about this comment. Most if not all cars have preset curves so the car will run fine if the MAF goes bad. The car just can't adjust for current atmospheric conditions.
Old Oct 10, 2005 | 11:38 PM
I dont believe the MAF meter has anything to do with the VSC or traction control lite though?????the check lite comes on whenever there is a malfunction with those displays........
Old Oct 11, 2005 | 12:43 AM
jdmrider's Avatar
thanks for the replies, I went ahead and disconnected the battery, (before I seen the fuse reply) DOH I also took the maf off and cleaned it with alcohol we'll see
Old Oct 11, 2005 | 12:53 AM
I hope that will work for you...however I tried as well and after aprox 90 miles the lites came back on .....i will post again on monday once i get the problem diagnosed by toyota.....
Old Oct 11, 2005 | 02:06 AM
THE_DON's Avatar
Check the MAF...
-THE DON
It doesn't have to be BAD, just dirty. I had the same problem and it was because the MAF was dirty from intake filter oil. The car was still running fine, my dash just lit up like a Christmas tree.
-THE DON
Old Oct 11, 2005 | 10:26 AM
dgHotLava's Avatar
Check the MAF...
-THE DON
actually, a bad MAF will cause the ECU to go into limp mode.
the motor will not rev pas 3000 rpm.
could not do over 40mph...
Old Oct 11, 2005 | 10:35 AM
dgHotLava's Avatar
Check the MAF...
-THE DON
-THE DON
yeah, sorry if i made it seem like it had to be bad to throw the MIL.
i was trying to say if the car was running fine, don't buy a new MAF because it is not bad.
it could be dirty and need cleaning, but it is nod bad.
Old Oct 11, 2005 | 12:05 PM
jdmrider's Avatar
well coming to work today and wouldn't you know it the lights came on again oh well I guess I'll wait and see what happens with the one guy that's getting his diagnosed.
