check engine light is on
I was on the interstate today and all of a sudden my traction control shut off and at the same time my check engine light as well as the vsc light came on.
Has anyone else had this problem? What could be causing this?
I had the same thing happen to me I re-set the battery and about 90 miles later the problem happens again........vsc lite comes on as well as the check lite and trac control......i made an appointment for monday at the toyota dealer................
Originally Posted by O5Toaster-xb
have you installed a new cold air intake or something that would effect the ecu ?? If so you need to remove the battery cable for a few minuntes and let it reset !
the code came back as evap leak (small)
check the gas cap. take it off and put it back on tightly.
bottom line....unless you scan it for the code, this is just guessing.
Originally Posted by dgHotLava
Originally Posted by THE_DON
Check the MAF...
-THE DON
-THE DON
a bad MAF will not let the car run properly.
Check the MAF...
-THE DON
-THE DON
-THE DON
Check the MAF...
-THE DON
-THE DON
the motor will not rev pas 3000 rpm.
could not do over 40mph...
Check the MAF...
-THE DON
-THE DON
-THE DON
i was trying to say if the car was running fine, don't buy a new MAF because it is not bad.
it could be dirty and need cleaning, but it is nod bad.
