Help With Installation Of TYC TAil light
Old Nov 1, 2005 | 09:21 PM
Womenlover's Avatar
Default Help With Installation Of TYC TAil light
Hello To all, I Just bought a used pair of tyc off someone here and they did not come with bulb and i dont know what to do or how to intalled them can some one hel pplzzzzzzzzzzzzzzzzzzzzzzzz
Old Nov 1, 2005 | 11:15 PM
Killercarbonz's Avatar
Default help with lights
If you still have you stock taillamps the bulbs in your stock tails should work. just pop your hatch. Should be some bolt on the inside. Unscrew those and the lights should just pull out. Undo all the sockets and then replace them into the new taillamps. then just plug them back in.
Old Nov 1, 2005 | 11:25 PM
Womenlover's Avatar
I tried that and it is not the same bulb size
Old Nov 2, 2005 | 01:10 AM
koalaty2's Avatar
Try contacting http://www.elegantebytyc.com/contact.cfm they should be able to help with the proper bulb information. Taking out the OEM tail wire connection is a 1/4 twist to right (i believe) to take the connector off the back of the OEM's. Two nuts hold (a top and a bottom) hold the OEM's on. Same nuts are used for the TYC's. The wiring that comes with the TYC's adapt from the one connector used in the OEM's to the three individual lights with wires on the TYC's. Good luck. I am looking for the installation instructions, but I can not find them. If this does not help, let me know.
Old Nov 2, 2005 | 09:50 AM
Womenlover's Avatar
ok let me narrow down the question the problem is that i dont have the wiring kit that comes with the tyc tail light where can i buy it . because the guy who sold them to me did not have tjem and i did not know that to i got them
plz help
Old Nov 2, 2005 | 10:32 AM
dgHotLava's Avatar
you have to get in touch with the person/place where you bought them...
it is supposed to come with it....
Old Nov 2, 2005 | 12:01 PM
Nightshift's Avatar
Contact http://www.elegantebytyc.com/contact.cfm, maybe you can buy the wiring harneses.
WW
xBSciontist
Jun 18, 2019 03:06 PM
TheTripleC
Jan 4, 2015 06:46 PM
mrbadass03
24
Apr 21, 2004 02:17 AM
Slopoke21m
Oct 2, 2003 04:59 AM
randode
16
Oct 1, 2003 12:40 AM
