How to properly "re-teach" the ECU after clearing
Old Nov 11, 2005 | 04:39 PM
BeetC's Avatar
1UP Crew
Default How to properly "re-teach" the ECU after clearing
After installing my "kinda-intake", I got a CEL (check engine light). I did a search here and found out how to clear it, but all the threads were vague about how to re-teach the ECU after clearing the CEL. Most say "idle for 15 minutes, then slowly progress from easy to moderate to aggressive driving" or thereabouts. Following these directions, I got the car running fine but the next day the CEL lit again. My question is, does anyone know specifically what I need to do? Do I have to follow this teaching process more than once? What specifically is easy/moderate/aggressive driving? Does throttle position come into play as well? Thanks in advance guys....
Old Nov 11, 2005 | 04:45 PM
jmiller20874's Avatar
If you're still getting a CEL, you might want to get that code read. Take it to AutoZone or another local parts store that'll read your code for free. You may have another issue.
Also, what do you mean "kinda-intake"?
Old Nov 11, 2005 | 04:48 PM
ScionDad's Avatar
Yup...
The CEL should be a rare issue with a CAI addition. Unless of course...you damaged the MAF sensor.
BeetC's Avatar
1UP Crew
It's basically a MAF adapter and a K&N cone filter.
Click me for the thread then scroll to the last post.
Old Nov 11, 2005 | 04:50 PM
BeetC's Avatar
1UP Crew
Yup...
The MAF was babied...I'm sure I didn't damage it. The car runs fine after a reset with the stock airbox...it's just the adapter/filter that's setting it off.
Old Nov 11, 2005 | 07:45 PM
cee_dub2003's Avatar
PM sent with some advice....
Old Nov 12, 2005 | 02:04 AM
BeetC's Avatar
1UP Crew
Reply sent. Thanks for the help!!
Old Nov 12, 2005 | 04:08 PM
senseiturtle's Avatar
Can we all see this advice?
I'd like to do the same sometime soon.
Old Nov 12, 2005 | 06:57 PM
The cause of a CEL light on an intake is because the MAF housing is too large for the MAF to calibrate properlly.
drgonzo92
14
Apr 24, 2019 07:27 PM
krazylowgsx
Dec 18, 2016 04:13 AM
Rob54Monty
Jan 20, 2016 01:41 PM
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
