Throttle body cleaner
Old Nov 22, 2005 | 02:04 AM
gqdabien's Avatar
Default Throttle body cleaner
I have throttle body cleaner, i removed the intake but when i start the car it will die. How do i prevent the car from dying when i turn it on without the intake? The throttlebody cleaner instructions say to leave car on, and spray into the throttle body while moving the butterfly plate.
p.s. where is the lever to move the butterfly plate manually? thanks
Old Nov 22, 2005 | 09:12 PM
grizzly_choppers's Avatar
Um, don't do that. I don't care what the damn can says. NEVER spray cleaner into the intake of a running vehicle. I've seen two of the biggest fireballs I've ever seen take the skin off a technician's face because of this exact proceedure.
A good throttle body cleaner will be able to clean everything just fine without the motor running. You simply use it to blast any deposits off of the butterfly and body sides. If yours doesn't do that try another brand. I suggest Wynns A.I.C. (air intake cleaner).
If you're looking to clean the fuel system, buy an in-tank additive. I suggest the Toyota Fuel System Cleaner. It's a small can (like a V8 juice can) and treats the system very well.
Good luck and don't get yourself burned.
-Alex
Old Nov 22, 2005 | 09:42 PM
gqdabien's Avatar
what i did was just spray it at the butterfly, put hte intake back on and start the car. I can't figure out how to manually open the butterfly with a lever ? But i did this process like two times and the car started up really rough at first and died. but i restarted and it was rough but everything smoothed out after 2 minutes. is this normal? or should i take it into a mechanic to get things checked out?
Old Nov 22, 2005 | 09:45 PM
TheScionicMan's Avatar
It was probably just burning off any excess cleaner. If it has smoothed out you should be OK.
How dirty was it? How many miles on it?
Old Nov 22, 2005 | 10:01 PM
gqdabien's Avatar
i had 24k on it. I also put in fuel system cleaner into my last tank and changed the air filter for 2nd time. just wanted to make my car a little more reliable.
does ne1 know how to move butterfly plate?
Old Nov 22, 2005 | 11:03 PM
Pull on the throttle cable...
Old Nov 25, 2005 | 04:11 PM
jmiller20874's Avatar
What car do you have? If it's xA/xB, just tug on the throttle cable. If you have the tC, the butterfly is controlled electronically, and if you don't have your intake trac hooked up, your MAF won't read correctly and therefore won't operate the TB correctly so your car won't run correctly...get the idea?
Old Nov 26, 2005 | 09:18 PM
boostedscion's Avatar
wow 2 fireballs. what happen there?
Old Nov 26, 2005 | 09:33 PM
This stuff is highly flamable as is the propellant. With a running engine you can catch even a minor backfire through the throttle body and everything goes boom in a big way!
One was an Olds Intrigue and the other was an Olds Aurora (this is back when we were an Oldsmobile dealership too).
-Alex
Blunderbuss
Oct 8, 2015 04:56 PM
MeDizzy
Oct 8, 2015 03:31 PM
user9430961
Sep 24, 2015 01:09 PM
prescottn
Sep 13, 2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
