leaking coolant
Old Dec 24, 2005 | 08:23 PM
yellot00tr's Avatar
Default leaking coolant
i just got my car back from toyota-they installed the supercharger on thurs/friday. i picked it up last night, and i was just looking at it today, and i noticed that the coolant tank is basically empty. there's coolant all over the shield underneath the car, but the tank is basically empty. it's right above the "low" line. there's a little bit in the radiator-i can see it when i take off the radiator cap. what can i do until i get the car back to toyota on tuesday? is it ok to just get regular coolant from pep boys?
Old Dec 25, 2005 | 04:34 AM
FromThisSoil's Avatar
Not sure if the tC uses the Toyota Long Life Coolant or the Super Long Life Coolant, but either way, I wouldn't recommend mixing it with a store brand. Toyota SLLC is silicate-free phosphate-free and prevents corrosion.
If you're really in a pinch and it's not below freezing out, you could just top off with distilled water. Otherwise, you could top it off with a coolant from the store that's compatible with other coolants, I think Prestone makes one. If I were you and I did that, I'd drain the thing and refill it with the OE coolant.
Old Dec 25, 2005 | 04:48 AM
How far below the is the coolant line is the radiator? Is it just below the upper hose (top hose is loose) or is it past the top hose and/or below the bottom hose (bottom hose is loose)? I'd check that out and make sure the hose is on all the way and that the clamps are tight enough/on all the way.
Old Dec 25, 2005 | 05:47 AM
LiNxStEr's Avatar
Actually that happen to me also. I notice one morning when i was going to work that my coolant was leaking. Took it to the dealer and i found out that my radiator was damage and had a leak. Im not an agressive driver or hit anything. Radiator just broke on me =/
Old Dec 26, 2005 | 12:33 AM
yellot00tr's Avatar
this sux. the dealer's service dept isn't open till tuesday. i'm taking the car to a service place by my house tomorrow morning, and then i'm sending the bill to scion. this is really ____ing me off. it rained all day here today also, so i couldn't even go out and play with the thing. not only that, but i had relatives over all day. not very happy about this friggin mess toyota left me with.
Old Dec 27, 2005 | 12:57 AM
grizzly_choppers's Avatar
It's Super Long Life Coolant in the tC. Also everything Soil said above is what you should listen to.
Taking it to a shop and billing your dealership won't work unless you call the dealership first. It sucks, but approach it camly and they will treat you much better.
-Alex
Forced4
Aug 21, 2015 09:22 PM
Araygoza100
Jul 18, 2015 05:53 PM
StxArOne
Jul 13, 2015 06:25 PM
